First post from my fan-cooled 2.7GHz DP G5
    Intuition
    Posts: 1116 from 2013/5/24
    My God this thing is fast, it makes my 1.67GHz Powerbook feel like my A1200! :D
    Seesm to hover around 80 degrees under moderate load and the fans are on a constant low spin.
    On OSX they only spin up occasionally and really fast, then stop for a while. Repeat adfinitum.
  • »26.06.13 - 18:07
    xyphoid
    Posts: 870 from 2008/7/11
    NICE! Model# specs wares, and what's in it?
  • »26.06.13 - 22:05
    Intuition
    PowerMac G5 Model 7,3 (A1047)
    4GB RAM
    256MB ATI Radeon 9650 Pro with Dual-DVI Outputs
    24" 1920x1080p LED Panel
    300GB SATA HDD (50GB for OSX, 2GB PFS3 for System:, 248GB IceFS2 for Work:
    Will probably add a small SSD for System at some point.
  • »27.06.13 - 13:12
    Since you are running both MorphOS3.2 and MacOSX in a dual boot setup, does MacOSX show any error messages now that the liquid cooling system has been removed? I am just wondering how removing the liquid cooling system affect the operation of MacOSX, as I plan on keeping MacOSX 10.5.8 on my G5 PowerMac tower, along side of MorphOS3.2, and maybe even one or more of the PPC Linux distro's, like Mint, and/or Ubuntu.
  • »27.06.13 - 16:34
    Posts: 1094 from 2004/9/23
    Since MorphOS is running at 100% CPU load, it should be fine, but this is only a wild guess of course.
    Geit
  • »27.06.13 - 16:47
    Intuition
    OSX seems to run fine. I won't use it much though as I have a macbook pro that is much faster that I use for Logic Pro but mostly have it booted in to Linux.
    I may install Linux on the G5 at some point though.
  • »27.06.13 - 17:26
