WEP?
    bash64
    Posts: 974 from 2010/10/28
    Is WEP supported?
    I attempt to join a wireless network and it goes green but never asks for the password. The encryption is WEP.
    I never get DHCP.
     :-D
  • »22.06.13 - 10:04
    bash64
    Nevermind. I get it.
    MOS Devs consider WEP to be crackable so you do not support it.
    Thus you never get asked for the password.
    Which begs the question "Why on earth does the guest access at my workplace use WEP!!!???"
  • »22.06.13 - 10:22
    Lizard
    Posts: 34 from 2004/4/27
    Ehm, not completely:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=9235&post_id=102064&viewmode=flat&sortorder=0&showonepost=1
    jacadcaps states it wasn't tested...
  • »22.06.13 - 11:01
    Posts: 12537 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=9235&start=63
  • »22.06.13 - 11:20
    bash64
    network={
    ssid="mynet2"
    key_mgmt=NONE
    wep_key0=123456789abcdef123456789ab
    wep_tx_keyidx=0
    This works.
    Substitute you password for the wep_key0.
     :-D
  • »22.06.13 - 12:00
    bash64
    Damn.
    Spoke too soon.
    I forgot to unplug the ethernet cable.
    It does not work.
    Sorry.
  • »22.06.13 - 12:07
    Posts: 607 from 2003/4/11
    We will test that before the next update. There is most likely some bug in the WEP handling code.
  • »22.06.13 - 12:36
    bash64
    No big deal.
    Shocked my work place uses WEP.
    Thats scary.
  • »22.06.13 - 13:47
    Posts: 647 from 2004/4/15
    BTW Which encryption standards are supported for WLan in MorphOs?
  • »22.06.13 - 14:45
