G4 Powermac Hardware advice
    Posts: 1 from 2013/6/21
    Found a Powermac G4 with the silver drive bay covers on the street:
    http://www.everymac.com/systems/appl..._1.25_mdd.html
    Has 512 mb ram, 80 GB hard drive and two video out ports that match the photo of an ATI card RADEON 9000 PRO MAC EDITION (DVI)
    No keyboard, no mouse though. Thinking of USB keyboard, but there's only two USB ports, if I stick keyboard and mouse in there i have no USB. So what cheap keyboard/mouse can I use?
  • »21.06.13 - 01:58
    Posts: 3311 from 2003/3/5
    Any USB keyboard/mouse should just work. If you want more ports, get an el-cheapo hub, a pci USB 2.0 card or get a wireless kb/mouse set - that'd only use up one port.
  • »21.06.13 - 03:40
    Simon
    Posts: 809 from 2008/7/6
    or get a USB 2.0 usbcard with a NEC chipset ... shouldn't cost you much on Ebay.
  • »21.06.13 - 04:40
