PowerMac G5 won't boot MorphOS
  • esc
    esc
    Posts: 160 from 2013/5/27
    Hi guys,
    I have successfully installed MorphOS to a Mac Mini G4 but my PowerMac won't boot from the cd. If I hold c, it eventually goes into Mac OSX. If I hold alt, it takes me to the boot loader screen but it never shows MorphOS. Not sure what the problem is. I'm re-burning the ISO to another dvd to try it. I can mount the DVD in Mac OSX just fine and see the files but I cannot boot it :(
    Also I don't have an Apple keyboard, only a PC USB keyboard, but that didn't matter for my Mac Mini.
  • »15.06.13 - 14:12
  • esc
    esc
    Disregard, it magically booted this time...?
  • »15.06.13 - 14:41
    Cego
    Posts: 738 from 2006/5/27
    try the new ISO image. you probably still have the old one which caused problems with booting.
  • »15.06.13 - 14:42
  • Dav
    Posts: 10 from 2013/6/8
    When did the new image come out?
  • »15.06.13 - 22:01
    Posts: 12558 from 2003/5/22
    https://morph.zone/modules/news/article.php?item_id=2046&comment_id=7408&mode=thread
  • »15.06.13 - 22:57
    Posts: 1095 from 2004/9/23
    Sounds more like your cd drive had a good moment.
    It is unlikely that your disc is broken unless you downloaded it within the first 4 hours after 3.2 release.
    Geit
  • »16.06.13 - 06:55
    pampers
    Posts: 1071 from 2009/2/26
    Imho using ALT (Os menu) instead holding C is much more reliable option.
    MorphOS 3.x
  • »16.06.13 - 08:48
  • esc
    esc
    It's definitely a superdrive issue; after trying over and over again, eventually it just worked. Not sure why. Oh well :) I have little reason to boot from CD/DVD again now that morphos 3.2 is intalled. Using a CD/DVD after booting seems to work fine, so no big deal.
  • »16.06.13 - 11:39
