Soundblaster Live! on G5 machines?
    realstar
    Posts: 298 from 2003/2/24
    Hi. Is anyone else using a soundblaster live succesfully on G5? I bought a PCI sb0220 emu10k SB Live card and put it into my 2.3GHZ G5 Mac but can not get any output or input to work even though the driver does appear within AHI. Any idea what is happening here? I was really hoping to record audio on this system and the internal apple driver doesn't support input and now my SBLive is not working...
    Here is the PCI Scan ouput for the card
    BoardObject 0x2000FC64 Owner <>
    Bridge <pci1> Bus 6 Dev 3 Function 0
    Vendor 0x1102 <Creative Labs> Device 0x2 <SBLive! 5.1 Digital Model SB0220>
    Revision 0xA Class 0x4 <Multimedia controller>
    ProgInterface 0x0 <>
    Command 0x5
    -> I/O Access
    -> Bus Mastering
    Status 0x290
    -> Capabilities List
    -> Fast Back-To-Back
    DevSel: Medium Devsel Speed
    Cap_List: Head CapPtr 0xDC
    Cap_List: CapPtr 0x6010001
    Cap_List: CfgIndex 0xDC
    [0x1] PMC
    -> PME_Support 0x0
    -> D2_SupportFW
    -> D1_SupportFW
    -> Aux_Current 0x0
    -> Version 0x1
    PMCSR
    -> Data_Scale 0x0
    -> Data_Select 0x0
    -> PowerState 0x0
    PMCSR_BSE
    Data 0x0
    IOBase: Address 0x2000F5EC
    Base 0: Address 0xDFFCE000 Size 0x20
    [ Edited by realstar 15.06.2013 - 02:41 ]
  • »15.06.13 - 08:38
    pampers
    Posts: 1061 from 2009/2/26
    It's a known bug (that PCI cards doesn't work in G5), should be fixed in next release.
    MorphOS 3.x
  • »15.06.13 - 10:38
    realstar
    OK. Glad to hear it's a known issue that can be resolved with an update.
  • »15.06.13 - 11:47
