Moderator
Posts: 2555 from 2003/2/24
All 1.67GHz PowerBooks can take 2GB and even if MorphOS only see 1.5GB of that it makes no sence to upgrade to a smaller amount.
Given by the RAM-modules you linked I assume you either have a 5.8 (15") or 5.9 (17") PowerBook. These can take the 2GB in 1 module.
Might be a bit cheaper than 2x1GB. 2nd RAM-slot is 100% ignorec if 2GB is installed in the other.
If your PowerBook is a slighly older 5.6 or 5.7 you'll need 2 modules 1GB each, but some of these units (only 5.6 AFAIK) suffer from 1 slot being dead limiting it to 1GB.
