Posts: 1116 from 2013/5/24
My Powerbook has been left plugged in and switched on with the lid closed for about 12 hours or so.
I've just opened the lid and it's still running but the trackpad doesn't move the mouse pointer and the button doesn't work either. I thought the whole OS had locked up at first, but the pointer moves with RAmiga+Cursor keys and I'm using Odyssey to post this now.
I saw in the changelog for 3.2 something about a problem with the trackpad stopping when the temp sensor changes or something along those lines being fixed now.
Is this the same problem? I'm running 3.2 btw.
