TV out?
    bash64
    Posts: 977 from 2010/10/28
    I thought TV out was going to be supported in 3.2?
    I do not see it in the release notes.
  • »29.05.13 - 20:33
    Posts: 1095 from 2004/9/23
    I guess you mean the DVI Connector on your PowerBook. No one said it will be supported.
    TV-Out is something completly different and supported since ages. All you need is to set up a PAL or NTSC resolution and connect a TV by using an S-Video cable to TV out port of the radeon.
    It is funny how the "Please release the os at current state, even if unfinished!" mood after release turned into "Why no internal wifi? Why no display out? Why no ..." :-)
    Geit
    [ Edited by geit 30.05.2013 - 02:17 ]
  • »29.05.13 - 22:17
    bash64
    Ahhhhhhhhhhh.....but they DIDN'T release it early.
    It was released on time.
    And I am referring to the DVI connector, not analog.
    And someone did mention it being supported.
    [ Edited by bash64 29.05.2013 - 20:41 ]
  • »29.05.13 - 22:41
    Posts: 2220 from 2003/2/24
    bash64,
    Didn't happen until Andreas gives us an URL :)
  • »30.05.13 - 02:49
    Posts: 12558 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=32&topic_id=8882&start=73
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=32&topic_id=8882&start=75
  • »30.05.13 - 06:10
    bash64
    There is a mirror setting?
  • »30.05.13 - 13:43
    That's what has been claimed by a user a few months back. But according to geit, there's none.
  • »30.05.13 - 13:57
    bash64
    My experience is that if you hook up the dvi it will work in mirrored mode, it will just be synced wrong and appear misshaped on the larger external screen. Mine was shrunk inwards from the left and right, but it was there. I was thinking there was a mirror setting that would fix the sync issue.
  • »30.05.13 - 15:17
