How do you config a SB Live on MorphOS 3.1?
    TheMagicM
    Posts: 1220 from 2003/6/17
    Searching didnt help much...can anyone guide me on how to do this?
    model # is SB0410 also tried a SB0020
    If these model #'s are not compatible... Please LIST the ones that are.  :-/
    In MorphOS Preferences I do not see a SB Live to select
    thanks
    [ Edited by TheMagicM 24.05.2013 - 00:03 ]
  • »24.05.13 - 01:50
    boot_wb
    Posts: 874 from 2007/4/9
    The SB0020 (which appears to be a Soundblaster Live! based on a emu10k1) should be compatible, assuming it works.
    http://en.wikipedia.org/wiki/Sound_blaster#Sound_Blaster_Live.21
    The SB0410 (being a Soundblaster Live! 24-bit based on a CA-0106) will not work.
    http://en.wikipedia.org/wiki/Sound_Blaster_Audigy#Sound_Blaster_Live.21_24-bit
    Basically any emu10k1, emu10k2 (CA-0100) or emu10k2.5 (CA-0102) based audio card should work.
    The wikipedia links above are pretty good for checking individual model numbers.
    A few envy24HT based cards also work, although I've not personally tested them in a Powermac.
    http://www.audio-evolution.com/drivers_mos/
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »24.05.13 - 02:37
    Posts: 12572 from 2003/5/22
    > model # is SB0410
    Not compatible as boot_wb has outlined.
    > also tried a SB0020
    Are you sure this isn't SB0200?
  • »24.05.13 - 06:32
    TheMagicM
    Yes, it actually says SB0200..but the chip does say EMU10K1X on it. Are these automatically recognized by MorphOS? If so but it doesnt show up that means the card doesnt work?
  • »24.05.13 - 09:14
    I recommend to read the last 3 of the 5 links I gave you there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9205&forum=11&start=1
    This should make things clearer for you with regard to the SB0200 model with EMU10K1X chip.
  • »24.05.13 - 09:30
    TheMagicM
    damn. Ok, the search goes on.
  • »24.05.13 - 09:34
    Doffo
    Posts: 508 from 2010/10/14
    I had good luck on SB cards working on my MDD. Even was given a Dell SB live which worked great. Not sure if it was luck of the draw or if it was one Dell OEM card that happened to work. Could try putting the card in another PCI port just to be sure it is getting recognized in the Sound preferences.
    Either way, good luck!
    YUUUP!
  • »24.05.13 - 12:36
    TheMagicM
    Tried that...
  • »24.05.13 - 12:43
    TheMagicM
    I picked up a CT4830 Sound Blaster Live PCI card..booting up to MorphOS on DVD, recognizes the card but still no sound.
    I selected Emu10k, in Sound I set to all AHI units, but sample sound plays nothing and loading a game, for example like Chromium, sound still plays thru the built in speaker.
    [ Edited by TheMagicM 25.05.2013 - 18:04 ]
  • »25.05.13 - 19:04
    TheMagicM
    ok, with the help of user "hak" on #MorphOS IRC, I had to set the "Music Unit" 0 to be emu10k and now audio works. Close this one out. :-)
  • »25.05.13 - 20:32
