Where can I get a radeon small form bracket for Radeon 7000?
    XDelusion
    Posts: 602 from 2010/10/27
    I have an Efika with one of those black cases of Ebay.
    Wondering where in the world I can order a small for bracket for it?
    Thanks in advance!
  • »17.05.13 - 19:48
    Not sure what you mean X.
    A half height rear bracket?
  • »17.05.13 - 22:31
    SoundSquare
    Posts: 1214 from 2004/12/1
    i guess you mean the bracket for the radeon gfx card ? if so, you can find it easily on the web. For example, here at Amazon : http://www.amazon.com/XFX-XFX-LPBRKT-Profile-Bracket-MA-BK01-LP1K/dp/B000HVRRJO
    Most of the time these are called "low profile brackets", google should help you to find something in your area.
    [ Edited by SoundSquare 18.05.2013 - 01:20 ]
  • »17.05.13 - 23:19
    XDelusion
    Those are what I'm looking for but ALWAYS they have teh S-Video posititoned at the top and the VGA at the bottom where as mine is reverse of that.
  • »17.05.13 - 23:23
    I think I would have to dig out a 7000 or 7500 just to remind myself what they looked like (I had several and there is still 1 or 2 left).
    Are you sure you want to bother?
    You are going to spend about $5 for one (if you can find that layout).
    You can get a much better performing half height Radeon 9000 for under $15 (including shipping).
    [ Edited by Jim 18.05.2013 - 01:19 ]
  • »18.05.13 - 00:16
    XDelusion
    At that price Jim, you are correct, why should I bother. :)
    It's hard to tell from the picture, but would this work?
    http://www.ebay.com/itm/Appian-Phoenix-128MB-Radeon-9000-QD-LP-PCI-DVI-VGA-4-Po-/140973784179?pt=PCC_Video_TV_Cards&hash=item20d2b13c73
    [ Edited by XDelusion 17.05.2013 - 20:57 ]
  • »18.05.13 - 00:54
    That is a weird one.
    Looks to have two 9000 chips on it and it uses some kind of break out cable to connect the monitors )total of four outputs) that they are not including.
    How about these 9250s?
    http://www.ebay.com/itm/VISIONTEK-ATI-RADEON-9250-128-MB-PCI-DMS-59-VIDEO-CARD-WITH-DUAL-VGA-ADAPTER-/200924751026?pt=PCC_Video_TV_Cards&hash=item2ec80c64b2
    or
    http://www.ebay.com/itm/VisionTek-ATI-Radeon-9250-WM9250128PUPC-128-MB-PCI-Graphic-Card-/271205163872?pt=PCC_Video_TV_Cards&hash=item3f25166360
  • »18.05.13 - 01:19
    XDelusion
    Big placed, thanks!
  • »18.05.13 - 01:32
    Yeah, I just had to switch back to a Radeon 9000 in my Power mac because I needed 3D support.
    R200s work pretty good under MorphOS.
  • »18.05.13 - 01:38
