G4 PowerMac does not power on after shutdown
    TheMagicM
    Posts: 1220 from 2003/6/17
    Strange issue I noticed after installing MorphOS on my G4 powemac M8841LL.
    After I shutdown my system then hit the power button, it doesnt power back up. If I pull the power cord or power off the surge protector, then plug it back in, it powers on.
    Is it the way MorphOS powers off the system?
  • »11.05.13 - 09:26
    stephen_robinson
    Posts: 746 from 2007/4/22
    I wouldn't have thought so, does it do the same when you shut down Mac OSX?
    It sounds more like a dodgy PSU in mac. : :-(
  • »11.05.13 - 10:07
    bash64
    Posts: 974 from 2010/10/28
    I have had this issue with a quicksilver.
    Eventually the mac went bad.
    I use a Powerbook now and the power off is abrupt but at least it comes back up.
    If it didn't there is a 4 finger salute you can do to clear the pram (or something like that).
  • »11.05.13 - 10:53
    Doffo
    Posts: 508 from 2010/10/14
    I actually ran into this same exact issue. My G4 MDD is the FW800 version that came with the dual 1.42 CPUs. After using the computer for awhile and I would power down, it would not come back on until you pulled the power cord.
    Its been awhile, but I changed out my memory and CPU. Not saying it is both causing the issue, but See what memory configuration you have. The very last memory module I had was actually bad, causing my MDD to behave erratically.
    If you are brave, and I assume you have an MDD, You should buy a cheap 1.25ghz single GPU card, OC the card to 1.5ghz, and exchange the CPU card. Keep the card that comes out as a spare.
    YUUUP!
  • »11.05.13 - 13:26
    TheMagicM
    Doffo: yep...that's the exact setup I have.
  • »11.05.13 - 18:01
    Doffo
    i even switched out the PSU and that still didn't solve my problem. Not sure what exactly it was. I also took out the battery since it was long gone dead. But for sure keep an eye on the memory modules and for the sake of, switch to a single 1.5ghz cpu.  8-)
    YUUUP!
  • »12.05.13 - 04:44
    Doffo
    double post...
    [ Edited by Doffo 12.05.2013 - 02:45 ]
    YUUUP!
  • »12.05.13 - 04:44
    nemesiswar
    Posts: 37 from 2012/11/12
    http://forums.macrumors.com/forumdisplay.php?f=145
    These guys here have given me awesome information about my macs over the years im sure they can give you some advice.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »12.05.13 - 06:28
    Posts: 3311 from 2003/3/5
    Did you try to reset the PMU?
  • »13.05.13 - 19:30
    TheMagicM
    PMU?
    EDIT: Found docs on google.. thanks! I'll try that out.
    [ Edited by TheMagicM 13.05.2013 - 17:44 ]
  • »13.05.13 - 19:39
    TheMagicM
    that didnt fix it..but my battery is bad also since it does not remember the time. Maybe thats the case...
  • »13.05.13 - 20:01
    Doffo
    Hmmm. Now that the battery was mentioned, I actually did put in a working battery back into my G4.. Worth a shot.
    YUUUP!
  • »14.05.13 - 00:26
