LONG FILE NAMES.....
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Hello,
    Anybody know how to change the name of
    long file names ???
    Like if i Record a MP3 with AmiNetRadio i can play them, but the file name is veeeeery long, i can not copy or rename them :-(
    Is there a program for it or am i screwed ? :-)
  • »25.01.04 - 13:47
    nels664868
    Posts: 117 from 2003/12/28
    When you list the file are the read/write bits set?
    Have you tried using the 'Protect' shell command?
    ie.
    Protect <very loooong filename> +rw
    If the read/write bits are unset Ambient will not allow you to copy or rename files.
    Hope this helps.
    nels
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »25.01.04 - 14:07
    Sphinx_Ra
    I tryd it it says:
    Bad template ?!?!
    Thx
  • »25.01.04 - 14:46
    Posts: 906 from 2004/1/24
    Maybe stupid but, on my miggy I used to use the <first letters of filename>#? option, so you could try: rename blablabla#? justbla.
    Otherwise you could use Dopus4; on the amiga it could rename long filenames as well.
  • »25.01.04 - 14:56
    Sphinx_Ra
    @Stevo
    I tryd Both options but no luck...
    It still says "Bad Template" :-(
    This is one of the very looooong files:
    HHUK UK HARDHOUSE HARDTRANCE + HARD NRG MASTERCLASS WITH = ANDY FARLEY = FIERCE CHOONS FROM THE MASTER OF U
    Not short huh :-)
  • »25.01.04 - 16:01
    hooligan
    Posts: 1948 from 2003/2/23
    wheehee.. trance. for me too :)
  • »25.01.04 - 17:42
    nels664868
    if the file name has spaces in it put " marks around it
    Ask Dr. Stupid,
    Dear Dr. Stupid,
  • »25.01.04 - 18:42
