Swap mouse buttons for usb mouse?
    LeftyFPB
    Posts: 2 from 2012/7/10
    I just got MOS 3.1 installed on a Mac mini, and so far haven't had any problems. I would like to swap the buttons on my mouse for left-handed use, but the option in the mouse prefs is labeled for PS2 mice only. I went ahead and clicked it just to see if it would work anyway, but no luck.
    Is there a way to swap the buttons around on a USB mouse? I suppose I could take it apart and physically change the button wiring, but I was hoping for a solution in software first...
  • »26.04.13 - 17:32
    Posts: 1090 from 2004/9/23
    Any commoditiy on Aminet doing this job should work perfectly on MorphOS.
    Just tried LeftyMouse from Aminet and it works. It comes even with source code.
    Geit
  • »26.04.13 - 17:50
    _bigdan_
    Posts: 70 from 2009/1/7
    Hum, i presume it's also possible with Poseidon settings. I'll check this next week.
    bigdan
  • »28.04.13 - 01:56
    Jeckel
    Posts: 133 from 2007/3/11
    For all mice:
    MorphOS Prefs -> USB -> Classes -> HID class -> Configure (button) -> Menu Quick Setup -> Mouse Swap LMB <-> RMB -> Save defaults
    For a specific mouse:
    MorphOS Prefs -> USB -> Devices -> your mouse -> Settings (button) -> Menu Quick Setup -> Mouse Swap LMB <-> RMB -> Save
  • »28.04.13 - 06:05
    _bigdan_
    Thanks Jeckel !
  • »28.04.13 - 07:07
