eSATA
    bash64
    Posts: 977 from 2010/10/28
    Any chance of eSATA for Powerbook G4?
    PCMCIA slot seems like the only way.
    Not sure it can handle the speeds though.
    Would like something better than usb 2.
    Wainting on Helios 3 from YomGUI. Already spoke to him on this.
     :-D
  • »16.04.13 - 18:28
    bash64
    Well, if it was an NEC chipset then I'd be closer to believing it also.
    Poseidon likes NEC.
  • »16.04.13 - 20:13
    Posts: 2577 from 2003/2/24
    And what would Poseidon have to do with SATA ????????
    AFAIK know there are no drivers for any SATA controller by NEC, the SIL3112 on the other side is well supported allready (as a PCI card).
  • »17.04.13 - 01:31
    Yep, Kronos nails it.
    Unless you want a USB interfaced drive.
    Forget externals.
  • »17.04.13 - 21:24
    Posts: 12558 from 2003/5/22
    ...or FireWire.
  • »18.04.13 - 05:23
    bash64
    Ah, must have been tired to associate Poseidon with pcmcia.
    FireWire 800 may be closer.
    What say ye YomGui?
  • »18.04.13 - 15:00
    bash64
    Will the above pictured controller work now or are we waiting on pcmcia support?
  • »21.04.13 - 18:10
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8503&start=12
  • »21.04.13 - 18:30
