Posts: 650 from 2004/4/15
Try to playing settlers on my Power Mac G5@2.0 GHz.
I just copied the Settlers3gold folder to the root directory of the port.
When I start it, the game blocks at startup screen.
In the console window I can see that it loads the images, which goes on very slow.
Starte das Spiel
lade "Games:s25rttr_0.8/GFX/PALETTE/PAL5.BBM": fertig (14ms)
lade "Games:s25rttr_0.8/GFX/PALETTE/PAL6.BBM": fertig (8ms)
lade "Games:s25rttr_0.8/GFX/PALETTE/PAL7.BBM": fertig (7ms)
lade "Games:s25rttr_0.8/GFX/PALETTE/PALETTI0.BBM": fertig (12ms)
lade "Games:s25rttr_0.8/GFX/PALETTE/PALETTI1.BBM": fertig (7ms)
lade "Games:s25rttr_0.8/GFX/PALETTE/PALETTI8.BBM": fertig (12ms)
lade "Games:s25rttr_0.8/RTTR/COLORS.ACT":fertig (13ms)
lade "Games:s25rttr_0.8/RTTR/LSTS/splash.bmp": fertig (58ms)
lade "Games:s25rttr_0.8/DATA/RESOURCE.DAT": fertig (211ms)
lade "Games:s25rttr_0.8/DATA/IO/IO.DAT": fertig (100ms)
lade "Games:s25rttr_0.8/GFX/PICS/SETUP013.LBM": fertig (10168ms)
lade "Games:s25rttr_0.8/GFX/PICS/SETUP015.LBM":
How can I speed up loading the images?
EDIT: The sound fx is also broken.
But music just fine.
This whats the console says:
Games:s25rttr_0.8/RTTR/sound-convert: Datei ist nicht ausführbar
Games:s25rttr_0.8/RTTR/sound-convert fehlgeschlagen Rückgabewert 10
[ Edited by eliot 10.01.2015 - 12:21 ]regards
