Return to castle wolfenstein?
    Jambalah
    Posts: 820 from 2008/3/30
    @ Xyphoid:
    I'm using a RTCW Platinum Edition iso. Assuming you are using the same:
    CD1: Setup/data/main sp_pak.pk3 (280.2 mb)
    CD2: Setup/data/main autoexec.cfg (12 bytes)
    ----> --------------> hunkusage.dat (8 bytes)
    ----> --------------> mp_pak0.pk3 (60.2 mb)
    ----> --------------> pak0.pk3 (301.1 mb)
    All in the "Main" directory and then click on "Installer" to complete the installation via download.
    Now you have only to start...
    I hope this was useful ;)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »09.07.11 - 15:14
    Posts: 12471 from 2003/5/22
    > using the same
    He already described the file layout of his ISO image here in this thread. Going by that, it's definitely not the same.
  • »09.07.11 - 15:44
    xyphoid
    Posts: 870 from 2008/7/11
    so i got the wolfplat_1/2.iso's mounted but wolfplat_2.iso installs 1/4 of the way before i get an error. going phx's route
    dropping the files in got me an installation complete, but when started i got Sys_Error:VM_Create on UI fail with only quit option
    so it's a bust again!
    snoopium
    [8] [Single Player] [Open] [Nikki:Games/RTCW/main/rtcwkey] [Read] [Fail]
    [9] [Single Player] [Open] [/main/rtcwkey] [Read] [Fail]
    [10] [Single Player] [Open] [Nikki:Games/RTCW/main/language.cfg] [Read] [Fail]
    [11] [Single Player] [Open] [Nikki:Games/RTCW/main/wolfconfig.cfg] [Read] [Fail]
    [12] [Single Player] [Open] [TGLDEBUG] [Read] [Fail]
    [13] [Single Player] [Open] [TGLNOMIP] [Read] [Fail]
    [14] [Single Player] [Open] [TGLSYNC] [Read] [Fail]
    [15] [Single Player] [Open] [Nikki:Games/RTCW/main/image.cache] [Read] [Fail]
    [16] [Single Player] [Open] [Nikki:Games/RTCW/main/gfx/misc/sunflare1.tga] [Read] [Fail]
    [17] [Single Player] [Open] [JPEGMEM] [Read] [Fail]
    [18] [Single Player] [Open] [Nikki:Games/RTCW/main/model.cache] [Read] [Fail]
    [19] [Single Player] [Open] [Nikki:Games/RTCW/main/ui/assets/SMOKE-16bit.tga] [Read] [Fail]
    [20] [Single Player] [Open] [JPEGMEM] [Read] [Fail]
    [21] [Single Player] [Open] [ENV:Sys/ahi.prefs] [Read] [Fail]
    [22] [i2s.audio Config Process] [Open] [i2s.audio] [Read] [Fail]
    [23] [Single Player] [Open] [Nikki:Games/RTCW/main/ui_morphos_ppc.so] [Read] [Fail]
    [24] [Single Player] [Open] [Nikki:Games/RTCW/main/vm/ui.qvm] [Read] [Fail]
    [25] [« Requester Slave »] [Open] [muidebug] [Read] [Fail]
  • »09.07.11 - 16:09
    xyphoid
    got it line 23 ... i plugged it into main. i think i'm good now, i'll see how it plays :-)
    [ Edited by xyphoid 09.07.2011 - 14:28 ]
  • »09.07.11 - 16:27
    xyphoid
    @jambalah
    it quit again trying it your way
  • »09.07.11 - 16:39
    xyphoid
    in looking back at the snoopium log, i think i deleted those missing files out of main in the installer initially, when i started over, that may have
    been my 'most" recent issue with installing the wolfplat ver. we'll see when it's done installing
    Update all ok now...Thanks! ;-)
    [ Edited by xyphoid 09.07.2011 - 15:49 ]
  • »09.07.11 - 17:05
    XzIt
    Posts: 250 from 2005/1/19
    I tried RTCW on my macmini, its a bit low on the vram side 32MB, but other then that ok.
    got it running on medium/normal quality and 1280x1024 resolution.
    its runs very smoothly even on a 32mb vram machine, watched some of the videos/cutscenes was great, had one problem installing.
    failed at the copying of the last disk, some read error.
    i just manual copied the rest in and seems to work ok.
    XzIt
    Pegasos 2, G4 1 Ghz, 512mb ram, 500 gig hdd, MorphOS 2.7 Registerd.
    Mini Mac, G4 1.25 Ghz, 512mb ram, 40 gig hdd, MorphOS 2.7 Unregisterd
    Commodore 64, 128, Amiga 500, 600, 1200, 3000, 3x4000, CD32, CDTV
  • »18.07.11 - 07:50
    scrAb_
    Posts: 62 from 2010/7/23
    I got rctw-CD original version from a friend:)
    When launched, the Installer printed out "Failed Installation" immediately.
    It seemed, it couldn't load data from the media,
    (but the CD was mounted with rtcw label, I could browse its content).
    Anyway the installer went on downloading the update.
    So I tried to eject CD --> launch the installer again --> insert CD at request.
    Finally it loaded data from the media, started downloading the update and
    stopping it at about 10%...probably 'cause the updatefile was already there..
    "Main" folder, contains a lot of files now, but if I try to launch the
    game, I get "Incomplete Installation - Launch the Installer"
    Furthermore when inserted, the CD is shown as one only icon labelled "rtcw", but shortly before,
    Ambient asked me if I would it to be mounted, and if so, it showed two icons,
    one for data and one for audio tracks.
    Probably I've messed up something :-?
    [ Edited by scrAb_ 20.07.2011 - 14:49 ]
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »20.07.11 - 10:41
    Posts: 3264 from 2003/3/5
    @scrAb_
    I'd guess that the CD is damaged / your cd-rom doesn't handle it to well.
    Anyway, your best course of action would be to email bigfoot.
  • »20.07.11 - 11:18
    Simon
    Posts: 809 from 2008/7/6
    My Special Edition just arrived and it installed/plays without a single problem. I do suspect some people do not understand the concept "original installation media"
  • »21.07.11 - 10:25
    scrAb_
    I suspect your suspects are unfounded.
    The CD I have, IS an original one and in mint condition.
    Thank you for your help.
    PowerBook 5,9
  • »21.07.11 - 10:44
    It's not a question of original vs pirate, but original English vs translated edition (say, French). The installer doesn't work with translated ones.
  • »21.07.11 - 11:12
    scrAb_
    Obviously.
    PowerBook 5,9
  • »21.07.11 - 11:40
