Diablo port for MorphOS?
    beworld
    Posts: 664 from 2010/2/10
    Hello, i test it, it's working.. but game crash on exit...
    It's possible to have a native port ?
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »26.12.19 - 06:41
    tolkien
    Posts: 555 from 2013/5/29
    I have tried and it runs. A few graphics errores and can't be saved bit it looks promising.
  • »26.12.19 - 15:59
    Marlon
    Posts: 31 from 2018/2/9
    Native port should be easy enough. Ask Cowcat nicely and he'll likely provide. He's doing most of his WarpOS compiling/testing on MorphOS anyway.
  • »07.01.20 - 06:19
    waldiamiga
    Posts: 96 from 2007/7/25
    This version works, but needs some font.
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »07.01.20 - 16:20
    Posts: 12442 from 2003/5/22
    > needs some font
    Font can be downloaded from there, for instance.
  • »07.01.20 - 18:51
    Marlon
    > needs some font
    Here's the font that the amiga ports use: https://github.com/AmigaPorts/devilutionX/tree/master/Packaging/amiga
  • »07.01.20 - 22:27
    Thanks. I thought that the nicer CharisSILB.ttf could be used with the WarpOS version running on MorphOS as MorphOS hardware should be able to handle it.
  • »07.01.20 - 22:42
    Cool_amigaN
    Posts: 774 from 2011/11/30
    Tested the alt binary. It loads in split seconds in my system, I can create game and play however since it doesn't save/load it still needs some work to be done. Also, it crashes on exit (black screen), which is rather anoying tbh. Fullscreen/window mode and mouse grab on/off also work from diablo.ini. Btw, the main binary doesn't work (failed to create sound profile on SDL).
  • »08.01.20 - 09:19
    Marlon
    Just rename the CharisSILB font to the same name as the font I linked and it should work. It's currently hardcoded to use the other font for the Amiga platform, unless Cowcat changed that in his build.
  • »08.01.20 - 09:51
    waldiamiga
    > needs some font
    Ok, thanks. It's works.
    MorphOS.pl
  • »08.01.20 - 14:51
    Divinity
    Posts: 498 from 2009/9/8
    hello Marlon
    Is there also a 16bit version for WarpOS or only 8bit ?
  • »22.01.20 - 21:46
