Doukutsu Monogatari
    NicePics13
    Posts: 63 from 2007/3/9
    :-o http://amiga-news.de/de/news/AN-2008-07-00035-DE.html :-o
    There's a working OS4 layer for MorphOS, right?
    CBM Amiga 1200 + 4MB AMITEK with 33MHz 68882 FPU
    PowerBook5,4 1024MB 1333MHz G4
  • »08.07.08 - 17:18
    Korni
    Posts: 473 from 2006/2/23
    Itix should know. I don't know how os4emu runs on MorphOS2.0, it worked here with 1.4.5. Anyway i suggest you to ask author about sources, it's a SDL app so it shouldn't be a big problem to make a MorphOS version.
  • »08.07.08 - 17:54
    NicePics13
    Tried os4emu but it complains about wrong or missing elf.library.
    As I understand it Cave Story is freeware but not open source - Pixel, the author, has given permission and the source to port it to Linux x86/PPC, PSP, DS, GP2X and now OS4.
    Original Windows version written by Pixel.
    SDL/Linux port by Peter Mackay and Simon Parzer.
    Endian fixes by Peter gordon aka Xeron.
    AmigaOS 4.0 packaging and management by Johan Samuelsson aka Spot.
  • »08.07.08 - 20:58
    NicePics13
    8-) OK, contacted spotUP on safir if he was allowed/able to build a MOS binary as well.
    Unfortunately he wasn't, but was willing to help out if/when permission is got from Pixel and a decent SDL coder recruited.
    HAK! Where are you? :roll:
    --- edit ---
    Newer optimized SDL port on its way:
    http://aaiiee.wordpress.com/2008/07/08/cave-story-for-ps3-linux-is-nearly-done/
    [ Edited by NicePics13 on 2008/7/9 2:13 ]
  • »08.07.08 - 22:09
    Charvel
    Posts: 97 from 2007/2/15
    SpotUP has done A LOT of good ports for OS4.
    If someone wants to make some MorphOS versions of those I think he would be willing to help.
    Hes really good.
    Or better up. A MorphOS user could work with him to make even more ports for both OS4 and MorphOS :)
  • »09.07.08 - 03:21
    keropi
    Posts: 131 from 2006/11/11
    I wonder if this is playable on OS4 classic hardware...
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »09.07.08 - 06:38
    NicePics13
    Pixel is releasing the game on Wiiware so no more ports  :-/
  • »29.07.08 - 09:49
    BSzili
    Posts: 570 from 2012/6/8
    Time to do some thread necroing! This is only a debug build, but I compiled NXEngine for MorphOS. It should work okay, exept the fullscreen mode. Color keying doesn't seem to work there, and parts of the background obscure the foreground, rendering the game unplayable  :-(
    You can grab it from here.
    [ Edited by BSzili 14.01.2013 - 12:08 ]
  • »12.01.13 - 15:27
    scrAb_
    Posts: 62 from 2010/7/23
    Downloaded and my son is betatesting it on my macmini....not so bad.
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »12.01.13 - 17:24
    BSzili
    I fixed a serious bug, which trashed the currently held weapons in the save games. I changed the link in my previous post.
  • »14.01.13 - 09:12
    scrAb_
    Nice...downloading it again.  :-)
    PowerBook 5,9
  • »14.01.13 - 10:50
    BSzili
    I fixed the sound effects, it was an endianness issue. The #?.pxt files have to be re-extracted, so start a new drawer, and copy your save files (profile?.dat) there.
  • »15.01.13 - 13:17
    scrAb_
    It's me or you can't load saved games?....
    ...downloading again
    [ Edited by scrAb_ 15.01.2013 - 18:59 ]
    PowerBook 5,9
  • »15.01.13 - 15:58
    BSzili
    Just make a dummy-save before copy your old saves, or Load menu won't work. There's something in settings.dat to determine if there are any saves.
    edit:
    Or alternatively you can extract stuff in the new directory, and copy them over to the old one. Just make sure that you keep settings.dat and profile?.dat, or you'll lose your saves.
    [ Edited by BSzili 15.01.2013 - 19:35 ]
  • »15.01.13 - 16:07
    scrAb_
    Downloaded..."Need version 8 of powersdl_ttf.library"
    PowerBook 5,9
  • »15.01.13 - 17:00
    BSzili
    Grab PowerSDL from aminet.
  • »15.01.13 - 17:25
    scrAb_
    SDL updated. It loads the old saves too.
    thank you
    PowerBook 5,9
  • »15.01.13 - 17:58
    bash64
    Posts: 972 from 2010/10/28
    ok, how do i download the fixed version?
    Does it need 3D? Got powerbook so no go yet on that.
  • »15.01.13 - 19:41
    scrAb_
    You can grab it here
    It doesn't need 3D, I'm playing it on my PB. Anyway update SDL to the latest version.
    [ Edited by scrAb_ 16.01.2013 - 07:46 ]
    PowerBook 5,9
  • »16.01.13 - 04:45
    BSzili
    The "official" release is out, you can get it on aminet. There are no major changes, just the removal of some debug code. Plus I've been waiting for itix to release PowerSDL 16.0, which fixes the fullscreen mode in NXEngine :-) So make sure to get that one too.
  • »05.02.13 - 07:08
    Jambalah
    Posts: 820 from 2008/3/30
    Thanks BSzili!
    I'm playing this nice game and I'm enjoying it!
    @All:
    If you need translations:
    http://www.cavestory.org/downloads_game.php
    Copying the whole "Data" directory into the Game dir was enough for me. I don't know if this works for other languges so mmake a backip copy before.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »05.02.13 - 12:14
    BSzili
    I'm glad you like the game ;-) Thanks for the clarification too, I haven't checked where the game's text is stored.
  • »05.02.13 - 12:50
