E-UAE Setup
    pan1k
    Posts: 147 from 2009/1/20
    Hey Guys,
    I am trying to get my E-UAE setup. Just a minimal setup, Workbench Partition of 100MB and a Games partition of 2GB. I got Workbench 3.1 installed just fine, I want to copy my WHDLOAD setup over to my Games partition. I used FileImageCtrl and mounted the HDF file, and then used mounter to mount it, but it won't show up in Ambient. Trying to get to the file in the shell results in nothing. So I remounted it in mounter as FFS and then formatted it with Formater, but then E-UAE doesn't like it and it shows up as NDOS.
    What's the best way to go about creating a compatible HDF file for easy transferring of games? I'm just going to run WHDLOAD.
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »12.11.12 - 16:35
    Posts: 2182 from 2003/2/24
    I'm not too familiar with UAE or using HDF:s, but if you can't get that HDF mounted to MorphOS, maybe you could add filesystem partition to UAE, which would point to the location of your source WHDLoad setup. And if you're having working HDF in UAE too, just copy from filesystem partition to HDF partition within UAE.
  • »13.11.12 - 04:11
