Importing my Mac UAE setup..
    pan1k
    Posts: 147 from 2009/1/20
    I want to get UAE working on my Pegasos. I have a good setup on my Mac, it's actually a disk dump of my A4000T. Is there an easy way to use my mac config files on the Pegasos? It looks like they are completely different..
    I have 3 HDF's and the neccesary ROMs
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »26.08.12 - 18:58
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Completely different? It's exactly the same as the generic UAE config files. There are just additional platform files for display modes if needed. And i also supplied config files presets for A500, A1200 and "workbench" setups in the conf/ directory if needed.
    Making your HDF config should be the matter of changing the hardfile line and possibly the rom line to match your kickstart path, and that's it.
  • »26.08.12 - 22:23
    pan1k
    I'll work on it. Thanks for making the MorphOS Port! I can't wait to play games later!!
  • »26.08.12 - 23:06
    pan1k
    Ok, it's booting now, slowly but getting there. E-UAE complains about the gfx driver uaegfx is there a substitute?
  • »27.08.12 - 01:55
  • Fab
    Fab
    I wouldn't recommand UAE for regular workbench usage, since it's quite slow without JIT, but if you need it, then you need the P96 emulation, and it's only available in the SDL port. I supplied two binaries in the UAE archive: euae and euae.sdl.
    euae is faster (especially for games) and provides overlay output.
    euae.sdl uses SDL and supports P96.
    Make your choice. ;)
  • »27.08.12 - 10:48
    pan1k
    Yeah It is slow, but it works. I think I will focus more on creating a whdload setup for my games, since most of my apps run under MorphOS anyway. Thanks for the reply, it was fun getting it working!
  • »27.08.12 - 15:42
