MorphOS Developer
Posts: 1102 from 2004/9/23
Andreas_Wolf,
For wasting 1 GiB of HDD space, 8 padding "Apple_Void" partitions are needed, i.e. as much as 9 real partitions. I'd guess most people to have a significantly smaller number of partitions per HDD.
No, this may work when using some old partition tool, but using 10.5 install disk easily eats up to 1 GB between each partition. When using MorphOS only, only a few blocks are lost, but if you plan using leopard you get into trouble.
Having only 80GB, then loosing 3 or more GB is important.
My Systempartition is 16 GB in size and only 8 GB used. I just outsourced music, videos and emulators.
Geit
