Wing Commander Saga (aka PortThatThread)
    Posts: 2589 from 2003/2/24
    http://www.wcsaga.com/downloads/files.html
    I think we all loved the old Wing-Commander-games and since this freebie is based on the FreeSpace2-engine (and that had been ported some years ago) it should be portable. HW-requirements also seem reasonable low.
    I don't know the 1st thing about 3d-coding so just consider this as show those who do a game they might have missed other wise ....
    ...... still can't believe that I of all people am starting such a thread .... :oops:
  • »19.03.12 - 12:36
    hooligan
    Posts: 1948 from 2003/2/23
    Ya gettin' ooooooold!
  • »19.03.12 - 12:46
    Posts: 1521 from 2003/2/24
    Porting 3D game doesnt necessarily imply 3D coding skills are required. I have ported couple of 3D games without having any clue about OpenGL... so... go ahead and try it ;-)
    If you are lucky it is just configure && make.
  • »19.03.12 - 12:55
    pampers
    Posts: 1073 from 2009/2/26
    I've showed that to Stefkos and he asked a little but very important question - are there sources available?
    MorphOS 3.x
  • »19.03.12 - 16:08
    Posts: 919 from 2004/1/24
    Seems it isnt finished yet
    http://wcsaga.com/news-archive-2012/a-look-inside-wc-saga-s-beta-testing-part-4.html
  • »19.03.12 - 20:23
    Posts: 12577 from 2003/5/22
    Now it is:
    http://www.wcsaga.com/news-archive-2012/the-darkest-dawn-is-cleared-for-launch.html
  • »23.03.12 - 07:41
