Problems with RTWC installer
    rdenk
    Posts: 1 from 2012/1/25
    Since I'm an absolute newbie with Morphos I need some help.
    I'm trying to install RTCW. I have an original cd, which is in the cd-drive. Then I start up the installler, which does what it suppose to do. It installs the files from the cd and downloads and installs the update.
    Afte installing the update it returns to its original window. No 'completed installation' screen or what so ever.
    When I start RTWC- single player, the message ' Incomplete Installation. Please run the installer' appears.
    What I'm I missing or doing wrong?
    Rick
  • »01.03.12 - 17:39
    stephen_robinson
    Posts: 746 from 2007/4/22
    Dunno done it twice with no problems, the only thing that I may have done differently is put the game cd/dvd in when it asks for it, not before.
    Sorry if that's hopeless, but as I say, I didn't have a problem.
  • »03.03.12 - 09:47
    pampers
    Posts: 1071 from 2009/2/26
    Try to see, what Snoopium says.
    MorphOS 3.x
  • »03.03.12 - 12:36
    matt3
    Posts: 785 from 2004/2/10
    I had trouble also.
    So I installed on the PC and moved the folder over to MOS and it worked just fine...
  • »03.03.12 - 15:29
