MAME 0.120 - joystick not working
    TheMagicM
    Posts: 1220 from 2003/6/17
    Anyone having issues with joystick support? The fire button works fine, but movement does not. I have a Logitech USB joystick..works fine under Frodo and F1 Spirit.
  • »30.12.11 - 00:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Go to MAME input settings (tab key -> input general -> player 1) and bind the keys again.
    Joypad works for sure in MAME (i even killed my joystick on it :)).
  • »30.12.11 - 00:25
    TheMagicM
    Yes, I clicked on Settings then selected Joypad...only fire button works.
  • »30.12.11 - 00:43
  • Fab
    Fab
    I don't mean the settings in the GUI itself, but in MAME once the game is started (you press Tab and go to the entry mentioned previously).
  • »30.12.11 - 00:47
    TheMagicM
    got it..
  • »30.12.11 - 00:56
    xyphoid
    Posts: 870 from 2008/7/11
    i use a logitech too. make sure it is emulated correctly under sys pref
    settings>system>usb>devices>logitechxxx xxx-select>hid interface>rt click quick setup port 0
    never mind!
    [ Edited by xyphoid 29.12.2011 - 18:59 ]
  • »30.12.11 - 00:57
