Battle for Wesnoth 1.6.2 & 1.8 on Mos2.7
    AyoS
    Posts: 410 from 2003/8/13
    I have been playing Wesnoth on Morphos since 1.4... never had a problem until I upgraded to Mos2.7.
    I am wondering if there are libs that I should look to update to make it more stable?
    Also got a copy of 1.8... loads after several minutes, then crashes... I am guessing this was a first compile?? in Debug mode?
    Would there be issues with Lua??
    Thanks
  • »29.08.11 - 22:22
    AyoS
    Correction. Changed the powersdl lib from 15 back to 14.2? And now it works fine. Only problem is I get no music while playing...while normal sounds work...I have checked the settings and run snoopium to see that the program is reading the music file repeatedly but no music? Can anyone point me in the write direction? Not sure what's wron as it used to work.
  • »30.08.11 - 13:22
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Mh, i need to check again, but it should definitely work. Maybe you're missing one of the powersdl sub libs?
  • »31.08.11 - 22:07
    AyoS
    okay. My mos2.7 install is clean... must be missing more libraries...was pretty sure I had a complete setup like my past 2.3 setup.
  • »01.09.11 - 22:04
