GISH doesnt work correctly
    Ghost
    Posts: 15 from 2011/7/25
    i bought me the game GISH and installed on my MacMini with morphOS 2.7
    The game works, but the Fonts (ingame and menus) are not visible. I see only white boxes, so it isnt possible to navigate in the menu and chance game settings.
    MacMini G4 1.5Ghz - 512MB RAM - 80GB HDD - MorphOS 2.7 reg.
  • »03.08.11 - 18:20
    pampers
    Posts: 1061 from 2009/2/26
    Did you check with Scout is there any font missing in your system?
    MorphOS 3.x
  • »03.08.11 - 21:30
    boot_wb
    Posts: 874 from 2007/4/9
    Wouldn't it be fairly easy to implement a wrapper such that if a program requests/requires the use of a font which is not present, it defaults to - eg - system font?
    Not going to work well in all cases (eg for symbol, dingbats, etc) but would be better than displaying nothing.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »04.08.11 - 08:14
