Posts: 12577 from 2003/5/22
> Some versions of untgz are not uncompressing empty directories,
> so this may explain problem when trying to save
Yes, this was probably the problem I had back then. I didn't know that the solution was as easy as creating the missing save directory manually, but on the other hand I didn't investigate the issue deeply anyway.
> sadly free heroes 2 author have removed some AI code from sources due
> to some "bad ass" coders revamping his code for some commercial games...
> Full AI functionnalities are only available for Windows, Mac and linux binaries.
Ah yeah, I just read about that in the
source file. A pity.
