FodQuake is not an executable?
    XDelusion
    Posts: 602 from 2010/10/27
    I just tried out FodQuake...
    ...upon clicking on either executable MorphOS tells me that neither file is an executable.
    I get the same results from Command Line.
  • »21.07.11 - 15:17
    Krashan
    Posts: 1107 from 2003/6/11
    Looks like bigfoot forgot to set E (executable) attributes for files. "protect +e fodquake-gl" should do the trick.
  • »21.07.11 - 15:32
    XDelusion
    Thankx I'll try this after work.
  • »21.07.11 - 15:46
    Henes
    Posts: 507 from 2003/6/14
    Ambient ignores the executable bit.
    So the problem must be a different one.
    May I suggest using snoopdos/snoopium?
  • »21.07.11 - 16:17
    Posts: 1095 from 2004/9/23
    Are you should you downloaded the right archive?
    Here I can click and run from shell and the result is always that I need some gfx.wad game file, which I not own, so the binaries are working as they should.
    Geit
    [ Edited by geit 21.07.2011 - 21:21 ]
  • »21.07.11 - 17:20
    XDelusion
    I downloaded it from here...
  • »21.07.11 - 18:41
    XDelusion
    Resolved
    Icon info
    Set to Executable
  • »22.07.11 - 05:34
    XDelusion
    Hmmm, didn't realize this does not support single player yet.
  • »22.07.11 - 17:21
