E-uae and 2player games like Top Gear 2
    xyphoid
    Posts: 870 from 2008/7/11
    So one of my favorite games is tg2. Now I have the cd (cd32) and have a few options in running the adf or whd. The thing is I can't get either option to perform well. Firstly with whd, i got going through the igame/e-uae setup, where I boot up into a 1200. (if i could get the cd to work there that would be great, but mount cd0: complains of headers...ect) anyway when I go to topgear in whd it complains about kick 34005.a500. (most others work btw). The other option, my adf setup works, plays then after the first race is over gives the old guru-meditation..errr software failure(i assume it crashes due to not finding adf2). Using the multiple adf script opt for e-uae prompts for wb1.3. I already have three adf set-up it's hard to keep up :-o . Anyone got a solution. Be nice if I could copy everything somewhere, and just change the s/startup for the disk.
    strike ...got it going but se later posts on 2player....
    [ Edited by xyphoid 29.04.2011 - 00:47 ]
  • »24.04.11 - 14:55
    kriz
    Posts: 310 from 2005/10/18
    For the missing files you need the kickstart files to be added.
    "you need the actual kickstart files themselves, so in the above instance, take your kickstart 1.3 which you use for winuae, copy it to the Devs:Kickstarts dir, make sure its unzipped and rename it to kick34005.a500."
  • »25.04.11 - 00:18
    xyphoid
    Thanks,
    I'm using e-uae on morphos...so I created the kickstarts folder and dropped the necessary files in. Geeks! Now it says I have to register first to continue..
    [ Edited by xyphoid 24.04.2011 - 21:01 ]
  • »25.04.11 - 01:34
    kriz
    Some of the wdhload install are only avalible for regged versions.. But when I check this one: http://whdload.de/games/TopGear2.html
    It doesnt seem so.. You have the latest Whdload installed aswell ? Its worth registering though, whdload fixes really rocks!! 8-)
    [ Edited by kriz 26.04.2011 - 09:05 ]
  • »26.04.11 - 08:05
    xyphoid
    yea it's the latest. I tried the link ver of tg2, it requires the disk to install, but i have the cd, so no go there. I registered.
  • »26.04.11 - 19:27
    xyphoid
    ok, so I got my key, now how do I get player 2 stick to work? The usb mouse moves the options, but how do I configure the 2nd usb joypad for use? i assume port 0 for amiga, but didn't get anything to move. I got some movement for port 2 on the right analog stick, but no digital response,( movement nor bottons). player 1 currently works on my poseidon port 1 which is usually player 2 for mame. It is also player 1 on genesis plus when using that emulator.
    To recap how do I get two player mode going on euae?
  • »27.04.11 - 20:41
    xyphoid
    I've asked this a couple of times through different posts. Is there a way to get two player under euae? I'd like to play some 2player games under whdload through emulatioin, but can't get the second joypad to work. What's a setup which may work?
  • »29.04.11 - 05:44
