OnEscapee: chipram too fragmented
    XDelusion
    Posts: 602 from 2010/10/27
    Everytime I try to load up OnEscappe with the RTG updates, I get this error:
    What is that all about?
    Also, what is preventing Genetic Species from running in MorphOS?
  • »01.03.11 - 20:13
    Posts: 12499 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=2894&forum=16&post_id=24802#24802
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5848&forum=9&post_id=57951#57951
  • »01.03.11 - 20:31
    XDelusion
    Well I'll say one thing. DON'T buy MorphOS to play all those Amiga games you could never afford the hardware to play on back in the day.
    It's a shame there isn't some sort of work around to re-direct those direct calls to the Paula chip.
  • »01.03.11 - 21:30
    Posts: 3277 from 2003/3/5
    There is: it's called E-UAE.
  • »02.03.11 - 05:56
    XDelusion
    Yes, but E-UAE has no JIT for one, and secondly it does not support PPC, so I'm still at a loss.
    I think the only games that do work under MorphOS are WipeOut, which is buggy, Payback, which is also buggy, and Shogo which works perfect for some, and then for others like me, it has no sound. And no one seems to have a logical explanation as to why that is. :(
  • »03.03.11 - 02:58
    Posts: 1520 from 2003/2/24
    Payback: shouldnt 68k version work without problems? PPC version uses Paula directly but is there reason to use PPC version after all?
    Wipeout: you have to use loader to get rid of debug hack but should work?
    I never had those games but I have read many users running those games succesfully on MorphOS.
  • »03.03.11 - 03:45
    XzIt
    Posts: 250 from 2005/1/19
    well i never tried shogo, but wipeout is working flawlessly the only bug i have are at the start screens then its all good.
    btw you tried shogo launcher ?
    http://aminet.net/package/biz/titan/LauncherUpd
    maybe that helps in some way, cheers.
    X
  • »03.03.11 - 07:48
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5965&forum=16&post_id=58870#58870
  • »03.03.11 - 09:59
    XDelusion
    I'm pretty sure I tried the patches for both, but just to be sure I'll give it a go. Besides MorphOS has upgraded a couple version since I tried them last.
  • »04.03.11 - 02:23
    Jeckel
    Posts: 133 from 2007/3/11
    Wipeout already worked fine with MorphOS 1.x.
    (except the introduction screen that is black in full screen mode, just skip it)
    [ Edited by Jeckel on 2011/3/4 9:30 ]
  • »04.03.11 - 06:30
    Henes
    Posts: 507 from 2003/6/14
    You must also disable the videos.
    The game tries to open a 15 bit screen (which is not possible on many setups) to play them, fails and crashes due to a lack of basic error checking.
  • »04.03.11 - 07:33
    MaveRickPL
    Posts: 73 from 2009/12/30
    I have Shogo (original by Hyperion)...
    1. No Sound
    2. Big problems with installation. Installer can not generate regiter file "client". I dont know if its a problem with my ShogoCD or Morphos... Some my friend say its CD.
    MacMini & MorphOS
  • »04.03.11 - 11:58
    XDelusion
    Wipeout now works with the limitations listed here. So thank you!!!
    Shogo, I still get sound in the opening movie, but before I get to the actual game menu, I still get an error telling me I need to configure my sound device!
    This sucks! I was really hyped about playing Shogo. No sound is a deal breaker on FPS'. :(
  • »06.03.11 - 03:25
