Giana’s Return v1.0 released
    _DaNi_
    Posts: 154 from 2010/5/4
    Posted January 3, 2011 by Gianas-Return Team
    It was about time to get v1.0 out, unfortunately a bit later than expected, but well… here we go! :)
    Updated ports: GP2x, Wiz, Pandora, Amiga OS4, MorphOS, NetBSD
    New initial ports: Caanoo, AROS
    Other ports should be updated erm… well… soon :)
    Changes:
    - Several palette fixes for all tilesets
    - Various other smaller cosmetic graphics fixes
    - Four new ingame baddies
    - The levels are now 40 pixels higher and “fullscreen” on 320×240 devices
    - Modified trainer (hidden)
    - Modified two levels in the last world to make them easier
    - Fixed minor slipping bug when a bridge is crumbling and Giana stands stil
    - Added configuration menu:
    * Music volume control
    * SFX volume control
    * Key configuration (where keyboard available)
    * Joypad/Joystick configuration (where external joypad/joystick available)
    Download
  • »03.01.11 - 09:19
    Krashan
    Posts: 1107 from 2003/6/11
    "Commercial or non-commercial use of any kind is not permitted outside gianas-return.de"
    Sounds like a nonsense, how one plays a MorphOS game inside a website? Should I delete it right after downloading?
  • »03.01.11 - 10:12
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    I've got a GP2X and i cant even get to there website  :-?
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »03.01.11 - 15:15
    hooligan
    Posts: 1948 from 2003/2/23
    I appreciate the effort but why it has to be uglier and more unplayable than even the c64-version. Even the sounds are worse. hrrh...
  • »03.01.11 - 16:59
    Tcheko
    Posts: 544 from 2003/2/25
    Keep playing on the C64 version then. ;)
  • »03.01.11 - 17:05
    scrAb_
    Posts: 62 from 2010/7/23
    me too
    the download fails after few kb.... :-?
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »03.01.11 - 17:12
    analogkid
    Posts: 724 from 2004/11/3
    @scrAb_
    are you using a proxy server? My download failed until i disabled the usage of the proxy server.
  • »04.01.11 - 11:37
    MarK
    Posts: 641 from 2004/1/25
    the game is very well playable, and it really reminded me the past with my old C64... :)
    really very nice, thanks!
    bye, MarK.
  • »05.01.11 - 06:02
    scrAb_
    @ analogkid.
    Thank you. I got it:-)
    Mos crashes in window mode, works only fullscreen
    [ Edited by scrAb_ on 2011/1/5 11:22 ]
    PowerBook 5,9
  • »05.01.11 - 07:04
    XDelusion
    Posts: 602 from 2010/10/27
    Wow, you guys don't seem to be having any luck with this.
    I've been able to load it up just fine, this and the previous release, be it in a window or full screen.
    The game play rocks, the graphics are right on, the musick sounds great, and I love the end boss fights! I'd been following this project since it's humble beginnings on the Sega Dreamcast and I must say that I have not been let down in the least bit, which is not the case with OpenGG.
    My only complaint is that like many Amiga related games, when I go full screen, it will not stretch to fill it up, rather I'm stuck to playing it in the upper left hand corner, not unlike ADOOM on my A1200 and A600.
  • »03.02.11 - 04:23
    Simon
    Posts: 809 from 2008/7/6
    I also have no problems at all with this game.
  • »03.02.11 - 06:07
  • phx
    phx
    Posts: 70 from 2005/3/29
    And when there are any problems, just write me.
    BTW, an update is out, which fixes a transparency bug with 24 bits in the 3rd world.
  • »03.02.11 - 19:31
    XDelusion
    I guess I'd like to know if there is any way to resolve the (I must use only 1/4th of the screen in full screen mode) issue. :)
    Thankx for the awesome port!
  • »04.02.11 - 22:34
  • phx
    phx
    Full screen mode will automatically double the resolution to 640x480. So all you need is to configure a proper 640x480 screen mode which fits to your monitor.
  • »06.02.11 - 08:10
    XDelusion
    Alright, and this will relate to the screen mode issues which I'm sorting out elsewhere in this forum.
    Assuming I work them out, how then do I get Giana to goto this particular screen since it does not have MUI prefs?
    I did see there are options for SDL when I RIGHT mouse click on the upper left hand corner of the screen, but I've not yet read the docs, so maybe they will fully explain what all they do and how they work in relation to this.
  • »07.02.11 - 04:42
    Posts: 919 from 2004/1/24
    @XDelusion
    You might want to check if you have "Promote SDL screens" checked in SDL prefs. This might cause the problems you described. Solution: uncheck it :)
  • »07.02.11 - 14:58
    XDelusion
    OH yes, that issue has been resolved, thank you!!! Though I'm still curious as to how I get Giana to go for the 640x480 screen mode, as opposed to the 1024x786 one I use for my desktop.
    [ Edited by XDelusion on 2011/2/7 17:20 ]
  • »07.02.11 - 18:25
    XDelusion
    I now have Giana Running in full screen in 640x480. So it seems that it defaults to the first resolution listed in Monitors...
    BTW, I tried your update that fixes the bugs in 24bit mode...
    ...it only boots to a black screen for me, so I'm plying in 16bit mode.
  • »11.02.11 - 02:48
    _DaNi_
    try this opening a new cli:
    -fs -aa -b24 -ogl -hd if you have a 16:9 monitor
    [ Editado por _DaNi_ el 2011/2/11 9:27 ]
  • »11.02.11 - 07:27
