No sound when playing gianas return or 1941 deluxe
    Simon
    Posts: 809 from 2008/7/6
    I seem to have no sound when playing gianas return or 1941 deluxe ? I have a soundblaster Live that seems to work fine with Quake, DVD, cd ...
    I must be overlooking something, but I have no idea what.
  • »16.01.11 - 15:39
    Simon
    I did connect my speakers to the onboard sound of my powermac, and now it works fine ? So it has to be soundblaster related ?
  • »16.01.11 - 16:48
    Krashan
    Posts: 1107 from 2003/6/11
    Check your AHI settings (music unit, unit 0).
  • »16.01.11 - 17:39
    Simon
    That seemed to do the trick ;-)
  • »16.01.11 - 18:34
    _DaNi_
    Posts: 154 from 2010/5/4
    If you have the last beta sdl library v15 installed have problems with both games, use the version 14 work fine
  • »16.01.11 - 21:41
    Simon
    I have version 14, it was just me that forgot (again) to change all the units
  • »17.01.11 - 16:24
