PERFECT PAINT !!!
    Sphinx_Ra
    Posts: 276 from 2003/3/15
    Hello Everybody....
    Anybody have Perfect Paint working
    on our lovely Pegasos ???
    When i select CyberGraphix in the
    Tooltypes nothing happens, only a
    screenmode requester and select one
    then pushing "OK" and then......
    Nothing.... :-(
    Please help, i love that program :-)
  • »28.11.03 - 18:24
    hooligan
    Posts: 1948 from 2003/2/23
    Starts but can't say it works.
  • »28.11.03 - 18:50
    Sphinx_Ra
    If you know how it works,
    Please let me know :-)
    Thanks
  • »28.11.03 - 18:58
    Doraemon
    Posts: 137 from 2003/7/1
    I want it too.......
  • »28.11.03 - 23:19
  • Targhan
    Posts: 2833 from 2003/2/8
    Yes, this is an application many have wanted to have working. I would like to try it myself!
    :idea:Targhan
  • »29.11.03 - 00:59
    Sphinx_Ra
    Targhan:
    Yes indeed, oke try it and
    let me know, i would be very
    happy if someone get's PPaint
    to work :-)
  • »29.11.03 - 01:06
    4pLaY
    Posts: 80 from 2003/2/17
    Sorry dissapoint you here but ive tried perfect paint out and i cant get it to work either (and the source is in 68k asm) so a port to MorphOS is very unlikely.
    http://www.resistance.no
  • »29.11.03 - 01:28
    Sphinx_Ra
    Yes you are dissapointing me :-)
    But why does a lot 68k programs
    works and not PerfectPaint ???
    But a port for MOS is indeed
    unlikey because i contact severly
    times the author
    but he never reply's :-(
    But is the problem 68K really??
    Or does problem causes by some
    library's ???
    I really want to know because like
    the GFX mode is the same (CGFX or Picasso)
    as the Amiga ?!?!
    Please let me understand the problem why it's not working, because i'm really sick of it :-)
  • »29.11.03 - 01:44
    4pLaY
    Heh well i seriously dont know i havent seen the sources myself! but i can only think that its dependant of the custom chips in some way! how hard it would be to change this i dont know but i doubt the author would do it as he is no Pegasos user.
  • »29.11.03 - 01:59
  • HAK
    Posts: 225 from 2003/2/24
    @ Sphinx_Ra,
    >Anybody have Perfect Paint working on our lovely Pegasos ???
    Well, depends on your definition of "working".
    I can start PerfectPaint and work with it a little bit, but it is not very stable.
    However I never did much with it as I'm not a graphician (I only used it for cutting brushes from a picture).
    We had this problem (not starting) already at the Betatester2 mailinglist some months ago, but AFAIK it never got solved why it didn't work at the other ones Pegasos.
    All I can say is that I had to add "RAMDEBUG" at the boot option otherwise I never was able to start it here.
    Bye HAK
  • »29.11.03 - 01:59
    Sphinx_Ra
    Work a little bit ?!?!
    That a lot further than me :-)
    add "RAMDEBUG" ?!?!
    MUST I PUT THAT IN TOOLTYPES OR SOMETHING ??
  • »29.11.03 - 02:12
  • HAK
    @ Sphinx_Ra,
    No, that is something you have to do in the OF.
    Short explanation:
    In the OF there are several environment variables that are responsible how the Pegasos reacts during booting.
    One of those is "boot-file". Normally its value is "boot.img", meaning that during startup the OF looks somewhere (depending on another environment variable) for a file called "boot.img" and loads/starts it.
    Without anything else this means also, that any debug message will be sent to the serial port where they can be read from another computer that is connected to it.
    You can add several parameters that change the behaviour of MorphOS during startup. One of those parameters is "ramdebug". When adding this option debug messages will be sent to ram and can be read later on with a special program.
    Long explanation:
    For further information concerning OF and boot parameters please consult the Documents in Sys:Docs, especially SFUserManual.pdf and SmartFirmWare.pdf.
    To-Do:
    To change the value for the next booting just stop the OF before it starts with booting MorphOS and insert "boot boot.img ramdebug".
    This will boot MorphOS with the option set (what makes Perfect Paint running here).
    If this works you can change it permanently by entering "setenv boot-file boot.img ramdebug" in the OF.
    Caution:
    TAMPERING WITH THE OF CAN LEAD YOUR PEGASOS IN A STATE WHERE IT DOES NOT BOOT ANYMORE.
    Back to business:
    To be honest, I don't know why the ramdebug parameter makes Perfect Paint run here.
    I just can assume that it throws that many hits (well the debuglog is at least 4 MByte big) that it would take ages if they are sent to the serial port leading to a lock of Perfect Paint.
    Sorry to be that long-winded, but as I don't know your knowledge of OF and boot parameters, I think it is important that you know that you can run into trouble when changing them, so you should at least know what you are doing.
    Bye HAK
  • »29.11.03 - 07:21
    Jupp3
    Posts: 1193 from 2003/2/24
    Wasn't it done in Blitz Basic, or am I thinking of some other graphics program?
  • »29.11.03 - 11:29
    Sphinx_Ra
    @HAK
    Thanks for the explenation :-)
    "insert "boot boot.img ramdebug",
    YES !!!! Cool thanks, that works :-) :-) :-)
    "Sorry to be that long-winded, but as I don't know your knowledge of OF and boot parameters"
    Well... nothing at all but now with your
    explenations a lot more :-)
    BTW It's not working properly, like if i
    change a picture size it's freeze, almost
    anything i change with the picture it's freeze,
    (Application is meditating)
    and the colors in the "Box" are not there :-(
    Do you have Picasso or CyberGFX in tooltypes
    enabled ???
    It is logic that CyberGFX is on i know, but
    you never know :-)
    Thanks
  • »29.11.03 - 17:26
  • HAK
    @ Sphinx_Ra,
    >BTW It's not working properly,...
    Well, I warned you. ;)
    I'm not sure, but I think it always comes into trouble when it opens a subwindow which contains a string gadget (like the resizing or crop window).
    >Do you have Picasso or CyberGFX in tooltypes enabled ???
    CyberGFX. IIRC it doesn't work with Picasso.
    Bye HAK
  • »29.11.03 - 22:39
    BatteMan
    Posts: 287 from 2003/2/24
    PfPaint is in BlitzBasic...
    BlitzBasic hits in hard by default, an the author can't do nothing...
    He can only reprogram it... and I don't think he wants to pass to the C.
  • »30.11.03 - 12:43
    Madgun68
    Posts: 60 from 2003/4/16
    As a general statement, this is not true. While some of the blitz libraries may not work with morphos, most of them do.
    There are ways of writing programs in Blitz that run perfectly under morphos. The bulk newsgroup decoder that I've been writing off and on for the last couple of weeks is written in Blitz2 and it runs not only flawlessly* under morphos, but much much faster as well.
    There are several things he could check to make sure it's as system friendly as possible:
    -Use the newest version of AmiBlitz.
    -Don't compile in the runtime error/debugger. That won't run under morphos.
    Barring that, either one of the libraries being used isn't system friendly or something in the code isn't system friendly. To say that it won't run just because it was written in AmiBlitz is rubbish.
    (* flawlessly meaning just as stable compared to running under AmigaOS.)
  • »30.11.03 - 13:48
    Sphinx_Ra
    @HAK
    Yep, you warned me :)
    So to the conclusion, it will
    never work proberly :-(
    Thanks anyway for the information :-)
    @Madgun68
    I believe that, did you try to
    contact the author as well ??
    Because i tryd, but no responses :-(
  • »30.11.03 - 14:49
