MorphOS 2.5 and Payback?
    redrumloa
    Posts: 1424 from 2003/4/13
    I found to my horror that I cannot find my PayBack CD, so I am trying to get the demo version working on my eMac. It loads, but freezes the system up in both modes.
    Anyone got it working on MorphOS 2.5 and eMac?
  • »12.06.10 - 21:15
    redrumloa
    Actually hardware render turned off seems to work with the non-WOS executable... Can hardware render be made to work?
  • »12.06.10 - 21:19
  • ASiegel
    Posts: 1376 from 2003/2/15
    Payback's PPC-native executable tries to access the Paula chip for sound output which is not available in your eMac.
    The 68k-native version, on the other hand, was updated by the developer to use routines that are not restricted to a particular sound chip. This was done to increase compatibility with Amithlon.
    This is why the 68k demo, which is slower in many regards, works for you but the PPC version does not.
    I would recommend that you play some other games instead :)
  • »13.06.10 - 03:57
    Posts: 1250 from 2004/2/8
    This is strange... I remember it worked quite well on my Efika with 2.4...
    ...and so it does on my Mini with MorphOS 2.5. I just run the PaybackSetup again and set all settings (even the software renderer). Then it just started working.
    [ Edited by koszer on 2010/6/13 9:34 ]
  • »13.06.10 - 05:56
  • ASiegel
    This has been discussed on MorphZone as recently as last year:
    Link
    If anything changed in the mean time, I am sure some visitors would like to know about it.
  • »13.06.10 - 06:50
    magnetic
    Posts: 2129 from 2003/3/1
    ASiegel
    should we discuss the Morphos port of this game??? :xx:
  • »13.06.10 - 08:34
  • ASiegel
    Some years ago, a native MorphOS port of Payback was planned. Is it abandoned ?
    Pretty much. Neither Nicolas Sallin nor I have got the required time to work on this.
    Source: Obligement
  • »13.06.10 - 09:15
