Robin Hood
    pecanK
    Posts: 70 from 2004/11/5
    If RobinHOOD freezes after launching,go to the data/sound and rename "Robin_hood.fxg" as "Robin hood.fxg".IN "data/characters" drawer rename "Friar_Tuck.rhs" as "Friar Tuck.rhs","Guard_A01.rhs" as "Guard A01.rhs","Officer_B01.rhs" as "Officer B01.rhs" and "Soldier_A01.rhs" as "Soldier A01.rhs"!Now it should work perfectly!REGARDS pecaN of the Czech PowerPC User Group
  • »14.02.09 - 10:44
    Daff
    Posts: 251 from 2003/4/5
    Thanks for the tips but the files in my installed Robin Hood was already named as you mention. And the game crash randomly.
    http://obligement.free.fr
  • »14.02.09 - 12:01
    XzIt
    Posts: 250 from 2005/1/19
    Don't hink my install has this problem.
    But only running demo version.
    Will check my install and game itself, let you know if i have any problems.
    X
  • »16.02.09 - 07:17
    Posts: 2221 from 2003/2/24
    For some reason, if you unpack it with XAD (browsing archive from Ambient for example), spaces become underscores. If you unpack it using commandline lha or lzx, then spaces are spaces as they should be.
    I thought I had some crashes when there wasn't memory enough, not 100% sure about that though.
  • »16.02.09 - 07:27
    amyren
    Posts: 219 from 2010/5/15
    Thanks for this tip about the spaces/underscore tip. Got my Robin Hood demo going now on mac mini, mos2.4.
    These posts have been made more than a year ago, before mos2.4 was available(?), and it still seems to be the same problem when unpacking from 2.4.
    Are the developers aware of this bug, and are they planning to correct this in any future release?
    (or is this XAD problem somhow related the pack ultimate 1.55, which is the only system addon I have made to my Mos2.4 installation)
  • »19.05.10 - 08:06
    Cego
    Posts: 739 from 2006/5/27
    is there now a way to patch the freezes in game? i would like to buy Robin Hood, but im still hesitating cause of the freezes.
  • »19.05.10 - 18:57
