UFO-AI help please
    Well, I finally downloaded both the FAB archive and the data .tar archive for UFO-AI to my PC (because it downloads faster) and burned the archives to a CDR to move to my G4 MacMini.
    I extracted the .lha files, but have not used my MorphOS computer for a while and have forgotten how to "un-tar" files to get the data files unarchived to my hard drive. I tried double clicking on the file and then copying the "base" folder to my games/ufo folder where the other files from the lha archive were and then tried to start the game. The error message I got was that I needed version 1 of the intl.library.
    Is this something that I should have seen somewhere else and missed?
  • »05.03.10 - 03:31
    Jupp3
    Posts: 1193 from 2003/2/24
    I think you need this, just copy the intl.library file to sys:libs/ - you don't probably need anything else.
  • »05.03.10 - 10:26
    kriz
    Posts: 314 from 2005/10/18
    yep, just copy it to libs: (its included).. It works fine but the game asks for some txt files ? Like not all is umpacked or something ? Same with intro , just says the txt file names..
  • »05.03.10 - 14:40
    Thanks Jupp3, that did the trick. I am surprised that the missing library is not mentioned anywhere in the readme file.
    I started the game up to test it, but have not made the time to play yet. Maybe tonight I will make some time for further testing.
  • »07.03.10 - 01:37
    osco
    Posts: 680 from 2009/10/20
    Sdl start up message
    "Need version 11 of powersdl.library"
    Aminet has it but I hesitated installing.
    Does morphos 2.4 have it already?
  • »08.03.10 - 23:01
