Heretic II black screen, but......
  • TGR
    TGR
    Posts: 100 from 2009/10/27
    Hey guys,
    I got around to installing heretic II and all goes well. so then the settings screen pops up and I select start game and the game begins to load and then turns to a black screen! So if I push the escape key it takes me back to the heretic II loading screen and then plays fine.
    Anyone have any idea what is causing this?
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »31.01.10 - 13:49
    Jambalah
    Posts: 820 from 2008/3/30
    No sounds? If I remember well, there are two video intros showingsome logos (epic and so on..) in a low resolution.
    Maybe those aren't supported or not played for any reason, letting you skip with esc key and come back to loading screen.
    I'm not able to test because I'm not able to find my heretic cds... in my room caos =)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »31.01.10 - 14:40
  • TGR
    TGR
    Thank you again Jambalah, your 100% correct it is trying to play some videos.
    Now and again the game suffers from the odd judder is this just the game? I've tryed making changes to the settings but still get it.
  • »31.01.10 - 20:00
    Jambalah
    No, it shouldn't.
    Are you playing in full screen mode? If so, try to play it in window mode choosing a resolution that could work well for your configuration.
    F.e: I used to play 1024x768 in a 1680x1050 Ambient screen. If your MacMini graphic memory is low or not (with Pegasos I'm using a 128 m ati radeon) exclude "enhanced display", since Tiny GL needs memory.
    Or, using a full screen mode, reduce screenmode (but I guess you just tried this) always excludin enhanced display.
    I found my cds but I will try tomorrow morning.
    Pegasos II 1 ghz
  • »31.01.10 - 20:49
    Posts: 423 from 2005/4/9
    @TGR
    could you explain pls how did you install it (step-by-step pls:) and what settings do you use? thx.
    zx.spectrum@3.5
  • »31.01.10 - 22:37
  • TGR
    TGR
    Yeah playing in full screen, the game wont go into any form of window mode. tryed using rtgmaster 68k which works fullscreen but not in window mode, rtgmaster mos results in not alot happing (no game). and not using rtgmaster results in full screen and no windows mode.
    I tryed reducing the window size and screenmode and predefined afew new screens and got the videos to work on 320x240 . but still has this little stutter/judder now and again. Its alot better on triple buffer but still happens so guessing it might be the slow mac mini hdd.
  • »31.01.10 - 22:40
