Neverball with MorphOS 2.4 hangs on Efika
    BalrogSoft
    Posts: 171 from 2006/10/6
    I tried Neverball and Neverputt, and both hangs my Efika at some points during the gameplay, no response. I configured it for lowest quality, but it seem that it doesn't matter, someone tried these games on Efika with MorphOS 2.4?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »05.01.10 - 07:00
    Posts: 1347 from 2004/2/8
    Both games work without problems on my Efika. And I've tested Neverputt quite well :)
  • »05.01.10 - 08:54
    BalrogSoft
    I will try to see log debug file to known what happens, i found that with MorphOS 2.4 some problems that was solved on MorphOS 2.3 related with pendrives and Efika, and the UAE4All executable after compile with 2.4 it isn't as stable than previous versions, i will try install MorphOS 2.3 again...
  • »05.01.10 - 09:45
    BalrogSoft
    I installed MorphOS 2.3 and now Neverball and Neverputt seems to work stable, and pendrives works again without problems.
  • »06.01.10 - 18:16
