Aleph One crashes with opengl on mac mini
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello, anyone tried to get Aleph One to run under morphos 2.4 on mac mini?. I tried but only works software mode. If i try to get opengl to run, it only stays at a black screen, and i'm unable to get out and had to shut off the m,achine by using the power button.
    Is anything special to be made in order for this game to work?. Treid with the infinity files, and neither loads on software or opengl renderer, only marathon 2 files.
    Thanks in advance!!!
  • »19.12.09 - 15:21
    _ThEcRoW
    Still trying to make it run, but no luck. Really want the opengl running into morphos because with that the game looks much way better.
    Anyone???
  • »21.12.09 - 13:05
    Chain-Q
    Posts: 347 from 2003/10/12
    I never tried this game before now, so i downloaded it now. Also the data files. It works for me on my mini, but it seems it needs 640x480 resolution, otherwise it bugs badly. So run it in 640x480, and it will work. With OpenGL of course. Both full screen, and windowed.
    (And a hint, if you got empty black screen with mouse cursor only, try Left Command - Q, to quit. That way at least you don't need to reboot. It's a common shortcut for all apps using PowerSDL.)
    [ Edited by Chain-Q on 2009/12/21 15:42 ]
    [.Hosting AmigaSpirit.hu.]
  • »21.12.09 - 13:42
