Question to Fab about Snes9x
    metalmac
    Posts: 87 from 2007/5/26
    Hi!
    Is it posible to conect a USB controller and use it with Snes9x?
    I have a working USB controller that I use with Genesis and Master system emulators, and that is working great.
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »17.11.09 - 08:06
    Jupp3
    Posts: 1193 from 2003/2/24
    Question to metalmac:
    Can't you just try and see if it works? :-)
    Generally most games that support joystick work just fine with USB joysticks, as long as the joystick is "standard", and you don't use more than 2 analog axis.
  • »17.11.09 - 10:05
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    @ metalmac
    My USB control (logitech dual action) works with Snesx9 without any problems.
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »17.11.09 - 11:38
    metalmac
    Ok, I have tryed the game Super off road, but that dont seem to work, will try another game then.
  • »17.11.09 - 12:10
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It works out of the box, but you need the joypad to be configured as lowlevel unit 0 or 1, IIRC (see poseidon prefs). I haven't tried with this game, but it worked for all the games i have here.
  • »17.11.09 - 12:18
