sharing files between morphos and WindowsXP with samba
    serge
    Posts: 725 from 2003/2/20
    I remembre sharing files between my old A1200 and Windows 98SE without problems with samba. But When I upgraded win98 to winXP, samba never worked anymore.
    Is someone reading me now and having samba working fine for sharing files between morphos and WinXP ?
    maybe printing to ;-)
  • »15.10.03 - 20:20
    Robert
    Posts: 331 from 2003/5/12
    @serge:
    Sorry I can't help you but I would like to know about this too. (Idiot
    proof info preferably :-D )
    I have a Pegasos, A1, Win98 PC and A1200 tower here.
    I'd love to be able to transfer files between them but haven't the
    foggiest where to start.
    I also just acquired a D-link 16 port Ethernet hub, which I'm hoping
    will make this easier.
    Robert.
  • »15.10.03 - 22:46
    Doraemon
    Posts: 137 from 2003/7/1
    I have the same problem with the ####ing winXP.
    Any idea?
  • »15.10.03 - 23:05
    Posts: 154 from 2003/4/22
    www.amigasamba.org
    quiet hard to configure but works well.
    I've tested it with 98, ME, 2k, XP.
    Bye
    MorphOS Rulez !
  • »15.10.03 - 23:24
    poundsmack
    Posts: 1346 from 2003/6/8
    @Robert
    "Make it idiot-proof, and someone will make a better idiot."
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »16.10.03 - 00:58
    tokai
    Posts: 1289 from 2003/2/25
    works here in the network too. just installed samba with the swat client and then configured samba on http://localhost:911/ with ibrowse. I share a directory here on morphos which can be seen under windowsxp.
    The other way around (mount a directory which is shared under windows) probably needs a bit more installing. :-)
  • »16.10.03 - 12:05
    Robert
    @poundsmack:
    Methinks I'm that someone. ;-)
    Robert.
  • »16.10.03 - 12:19
    serge
    I'm HAPPY HAPPY.
    It works now, after 2 long hours of search and investigation with snoopdos.
    Installation is hard. There is somethings missing in the main archive like SMBhandler. Configuring MIAMI is not realy very clear on docs. But now IT WORKS to share files. Last problem is to use a printer shared on PC to be used from pegasos. I dont know how to print on this share.
    Tango is a very funy tool ;-)
  • »16.10.03 - 22:11
    DSLCC
    Posts: 246 from 2003/5/14
    I just set it up after carefully following the instructions here:
    http://www.birrabrothers.com/tiger/data/samba/install/
    It is working just fine. :)
    David :-)
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »16.10.03 - 23:38
    Dietmar
    Posts: 114 from 2003/2/26
    Lucky you. I can't get internet connection sharing (ICS) to work with XP. I have a firewall installed on the XP server (the machine that is connected to the internet) and webwasher as proxie. Something somewhere stalls.
  • »17.10.03 - 02:44
    serge
    ok, so so so,
    I can mount devices shared on PC ( with TANGO ) . They are accesible from Ambiente shell, but there is not disk icon on Ambiente desktop ! I puted an disk.info on the PC disk share, but it dont appear !
    Any idea ? :-?
  • »17.10.03 - 07:44
    Posts: 125 from 2003/9/8
    I have no problems with my Peggy in big ethernet of PCs (WinXP). I can see all their shares, I can mount (problem is only when the share has a SPACE between a letter). When I mount it, it makes me an icon in Ambient. So sharing and mounting is possible.
    Have you "smbfs" in your C?
    You must have all properly installed (copied).
    JACK - 3D gfx artist
    Config: Pegasos 2 G3/600 MHz, 256 MB SDRAM (Kingmax), ATI Radeon 9200 Pro 128MB, 120 GB HDD
    My new web: http://jack-3d.wz.cz
  • »17.10.03 - 09:24
    Neko
    Posts: 301 from 2003/2/24
    Probably the best thing to do is stop using the big Unixy Samba.
    It's crap. It's not really meant for Amiga-like systems. Olaf Barthel did a great job porting it, but as it stands it's fairly crashy, fairly incomplete, and fairly difficult :D
    Use his "SMBFS" tool instead. You can mount Windows shares with it and access them as drives on your desktop. It definitely works with Ambient. Hopefully someday something similar will be built into Ambient or MorphOS rather than a seperate tool on Aminet ;)
    Unfortunately it doesn't do printing. That's still something we haven't gotten on the Amiga. I'm actually at a loss to work out exactly how it'd be done, too :D
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »17.10.03 - 12:40
    smbfs - try AmiNET
    and "smbfs" is in "lib" directory in Samba package, copy it into your "C". Then all shared directories will be showed on Ambient.
  • »24.10.03 - 09:06
    Posts: 16 from 2003/10/22
    Envoy works fine
    Easy to install
    Very fast
  • »24.10.03 - 09:41
