TurboPrint, Samba, and windows shared Printers
    serge
    Posts: 725 from 2003/2/20
    I would like to print to a Windows printer shared with samba.
    Samba is installed on peggy, I can see the printer doing a "SMBclient -L hostname" or with TANGO, but I dont know who to use this share with turboprint.
    An idea? :-?
  • »17.10.03 - 07:49
    Neko
    Posts: 301 from 2003/2/24
    As far as I know, you DON'T use Windows printers under AmigaOS or MorphOS. There isn't really any great support for it.
    What you'd have to do is print to a file (easy enough) and then somehow transfer that to the Windows box using smbclient (I think that's possible) or another tool.
    I think that method is explained here in this old magazine:
    http://www.btinternet.com/~clubbed/seal/totalamiga/backissues.html
    (but they don't have issue 8 available for download? how odd.. you can buy it from http://www.totalamiga.org though, which is the same site really)
    Someone on MorphZone had a question like this before ("printing on 1.4"?) so maybe you should check the archives too.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »17.10.03 - 12:37
