Duke Nukem 3D
    Coder
    Posts: 296 from 2003/3/5
    I downloaded Duke Nukem 3D and it starts fine but at the option screen it flips back to Ambient. I even upped the stack. Any ideas?
    Coder
  • »11.10.03 - 10:06
    klapdeur
    Posts: 132 from 2003/6/28
    where did you donload it i downloaded it but on my pc it wont install so i dont get the basic files to play and test this game. can you give some hints on that. or send me the wad files or whatever they are to play the game
  • »11.10.03 - 10:45
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    You can unpack the zip with VoodooX (xadmaster), too!
    No need for a PeCe... ;)
    I had the same problem with the exiting title....
    There are 2 solutions:
    - enter the game as fast as possible
    (i.e. press return serveral times till the game is there :)
    - upgrade your duke-mos port to 0.3 :)
    Good luck!
    frostwork
    PS: I played the game till the end
    There's just only one secret-level which hangs here:
    Area51, so don't enter it (or save under an other positions, than your actual one....)
  • »11.10.03 - 11:56
    Coder
    @tokai
    That did it. It works. What does /dd stand for? Anyway I can only select 8 bit screens with 800x600 the highest. Normal?
    Coder
  • »11.10.03 - 13:33
    klapdeur
    if i unpack the zip file i get duke3ds.1 file is this right and an install.exe file duke3ds files go to nr 5
    is this normal to play duke on peggy ???
  • »11.10.03 - 14:12
    Piru
    Posts: 605 from 2003/2/24
    As it disables the demos, I would imagine it stands for Disable Demos. :-)
  • »11.10.03 - 14:39
    Frostwork
    Hi, klapdeur!
    Sorry, lost the topic!
    You can extract the file duke3ds.1 with Voodoo-X....
    That's it what I meant, but didn't say
    bye
    frostwork
  • »13.10.03 - 15:51
    porneL
    Posts: 49 from 2003/7/16
    I have very same problem. Game quits to ambient as soon as player in demo falls into water.
    ...BUT before it happens you have like 1 sec. of working menu :)
    just hit enter quickly and start game!
    then you can go back to menu and set things up.
    this text is here to confuse you
  • »13.10.03 - 19:56
    klapdeur
    wel i tried that but voodoo-x had some errors with filetypes or something it doesnt reconize the files
  • »14.10.03 - 19:24
    Benke
    Posts: 6 from 2003/8/19
    Where can get those files?
    Regards Benke
    Mvh/Regards //Benke  :-D
    Visit The New Swedish Pegasos club's Site on http://pegasos.org
    Pegasos G3/600 64Mb
    Hyundai HY57V658020A No ECC, 4Gb FUJITSU HD Radeon 8500 64Mb
    Samsung DVD 16x
  • »14.10.03 - 21:55
    Britelite
    Posts: 68 from 2003/6/4
    I had exactly the same problem when running morphosDuke3D, but if I "Execute Duke3D" instead it works like a dream :)
    Basically you need to assign Duke3D:, increase the stack and use the /DD parameter when running morphosDuke3D.
    Hope this helps
  • »15.10.03 - 07:19
