Quake error
    Coder
    Posts: 296 from 2003/3/5
    I got Quake but when I start it I get the error " couldn't load gfx.wad" That file is in the directory. Anyone got any ideas?
    Coder
  • »11.10.03 - 17:39
    klapdeur
    Posts: 132 from 2003/6/28
    i think youre talking about quake 1
    wich version did you install?? i have mine from clickbooms nightlong cds no probs here.
  • »11.10.03 - 18:59
    Jupp3
    Posts: 1193 from 2003/2/24
    afaik, Quake needs following:
    Quake exe, in any directory.
    In the same directory, subdirectory containing files PAK0.PAK and PAK1.PAK (Config file & saves are also stored there)
    In addition to those, maybe a few libraries...
    Have you tried, if Snoopdos would say, what might be missing?
    (my 100th post)
  • »12.10.03 - 09:11
    Jupp3
    It seems that pak0 is missing. Is the whole quake package free for download?
    No, it's not, but I think, there's demo version out there...
  • »12.10.03 - 12:10
