Beats of Rage
    xyphoid
    Posts: 870 from 2008/7/11
    Is it my system, the need for a different BOR.PAK, missing a fix, or just that it takes 20mins to cache everything before it loads the game? I am using an efika.
    Posted with OWB
    [ Edited by xyphoid on 2009/2/16 18:48 ]
  • »16.02.09 - 22:46
    Nitro
    Posts: 106 from 2003/8/24
    If your running it on a partition that is FFS it will be extra slow. Run it on SFS.
  • »16.02.09 - 23:16
    Wishmaster
    Posts: 342 from 2003/6/29
    Try if "addbuffers drive: 600" helps.
    Pegasos PPC
  • »16.02.09 - 23:35
    xyphoid
    @Nitro aaahhh that would be the partition it's on, I'll move it then to the sfs partition
    addbuffers drive hd:x 600 ?(where hd:2=harddisk2)
    [ Edited by xyphoid on 2009/2/16 22:53 ]
  • »17.02.09 - 02:49
