Warzone 2100-2.0.8_RC1 Questions
    AyoS
    Posts: 410 from 2003/8/13
    Just wondering if anyone who has played this
    version of the game has had random Lockups
    with it? They almost always happen when alot of objects
    are on screen at the same time. I have scoured a snoopium log
    to see if anything I'm doing is causing this... Can anyone
    point me in the right direction?
  • »07.10.08 - 19:37
    Cego
    Posts: 738 from 2006/5/27
    yeah i have random lockups too, but dont know how to solve that problem. :-?
  • »07.10.08 - 19:43
    AyoS
    Have you used any of the earlier versions?
    If You did, did you find anything similar?
  • »07.10.08 - 22:36
    TheMagicM
    Posts: 1220 from 2003/6/17
    where can one download it from?
  • »07.10.08 - 23:21
    Posts: 12499 from 2003/5/22
    AFAIK the current one is only the *second* MorphOS version.
  • »08.10.08 - 00:11
    https://morph.zone/modules/news/article.php?storyid=1381
  • »08.10.08 - 00:15
    AyoS
    Was able to quit my second Job... and found some time
    to play with Warzone2100.
    I had problems with lockups... but usually happened when
    in the middle of a large fight... 10+ foreign units on
    screen at a time. I could always tell when it was going
    to happen as the sound would start to lag badly...then it
    would freeze. Using Scout I was sometimes able to get
    it to run if I kill the OpenAL process, but not always.
    Last week something in my brain "clicked" and I decided to
    take a different approach. Usually the program locked during
    a battle when cpu usage was near its highest. I had already added
    more stack... which seemed to help but wasnt enough.
    this time I thought to lower the priority of the main warzone2100
    process... Tada!!! Imediate difference... with the priority set
    to -50 It would start to lag badly.. but would usually not lock.
    so not 100% fix but better.
    Today I loaded Warzone2100-2.0.8_RC1 from the cli ... under the new Morphos 2.2,
    dropped the priority down to -20...
    ... And have yet to have a lockup... it doesn't even slowdown
    anymore... I'm running an 11 hour uptime at the moment with no locks!!
    After being crushed by my computer opponent no less then 10 times :-)
    Whatever You Guy's did with 2.2 it has made at least one app more
    stable!! Thanks!!
  • »22.12.08 - 02:01
    Daff
    Posts: 247 from 2003/4/5
    During the game :
    - Press "ESC".
    - Go to "Option".
    - Set "FX Volume" to "0".
    - Play Warzone 2100 for hours :-)
    For the moment, it's the only solution to play Warzone 2100 without lockup. This problem is quite similar to Robin Hood.
    http://obligement.free.fr
  • »23.12.08 - 12:21
    AyoS
    Thanks... I will do that... maybe release 2.1 will solve that
    problem.
  • »23.12.08 - 20:54
    Daff
    In Warzone, how do you use the satellite/laser weapon ? I have build all structures but it still unusable.
  • »24.12.08 - 04:26
    AyoS
    Good Question Daff I have spent all my time trying to find
    a way to trap the OpenAl bug that I haven't gotten that far. LOL
    (actually I would start to move forward and the program would crash...
    ticked me off more then once)
    Now that I have a temp solution I can put some serious time
    into playing!! Happy Holiday's Everyone!!!
  • »24.12.08 - 10:04
