MOS1.4 and gamepads,UAE,mame etc.
    Posts: 2533 from 2003/2/24
    Yes I know this has probraly been discussed a 1000 times, but I'm just
    to lazy to search for all that stuff.
    What I got :
    MOS1.4 (no UAE,mame or any other 3rd-party stuff needed for this),
    and an el-cheapo gamepad (guillemot-something in the on-board
    joystick-port).
    What do I need to make use of that ? Is there a test-prog available
    to test wether the pad is regonized ?
    How do I setup UAE or mame to make use of it ?
    Anybody managed to get CrossfireII working with such a pad ?
  • »21.09.03 - 10:35
    Jupp3
    Posts: 1193 from 2003/2/24
    I guess, it should work straight away, if you start mame like "mame.elf mslug joypad"
    At least it works for me... (Feel free to replace Metal Slug with worse game, if you want :-) )
  • »21.09.03 - 12:25
    *GRUMMEL*
    Tried the 1.4 lowlevel and Guido's but no success  :-x
    Anybody who can tell me what exact modells aresupported by
    what lib,and how to makeit work ?
    Or anybody working on drivers for some USB-pads ??
  • »21.09.03 - 14:21
