Using AmiGift on MorphOS
    Framiga
    Posts: 363 from 2003/7/11
    Druideck and Voodoo
    try to send me the whole Amigift dir (but the Completed one). I'll take a look for what i suspect is a wrong/old Amigift core component ;-)
    ah.. my address is in my profile.
    Sorry for the obvious question .... have you carefully checked to don't have ANY Amigift libraries in Libs:?
    and no old assigns as well?
  • »25.07.07 - 10:24
    amiga4001
    Posts: 449 from 2006/11/16
    Also here works with mosnet (peg2).
  • »25.07.07 - 17:58
    Framiga
    @ all with the Search/Stop issue
    thanks to an user on the Amigift ML:
    disable "FIOASYNC" in "Preferences>giFTMui>sockopts/modes" even if you are using MiamiDX. (that is/should be disabled anyway by default)
  • »29.07.07 - 13:59
    VooDoo
    Posts: 189 from 2005/8/24
    yeah is truth..whne disable this option AmiGIft works OK..no serach/stop problem  8-)
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »29.07.07 - 14:25
    magnetic
    Posts: 2129 from 2003/3/1
    Guys
    So the new Amigift works Out of The Box? I have Mosnet and 1.4 for this program.
    magnetic
  • »29.07.07 - 18:02
    Druideck
    Posts: 82 from 2003/5/6
    Pegasos 1/April
    Disabling "FIOASYNC" in AmiGift works for me too :)
    Thanks to all for the solution!
  • »30.07.07 - 02:13
    Solo_Kazuki
    Posts: 182 from 2006/7/23
    Did You try to contact with AmigiFT author for sources?
  • »11.02.08 - 14:25
