Western Quake (Quake III TC MOD)
    Solo_Kazuki
    Posts: 182 from 2006/7/23
    When i try to play single player game, after loading all medias, an error will occur:
    Error:
    Hunk_Alloc failed on 1431744
    Number is different, when i try other map (this one is from first map on the list)
    Is there anybody who played in Western Quake? What must i do to do this game working?
    [ Edited by Solo_Kazuki on 2008/2/11 13:09 ]
  • »11.02.08 - 10:09
    Korni
    Posts: 473 from 2006/2/23
    Single Player mode isn't really a Single Player mode ;). Anyway WesternQuake worked here, at least that SinglePlayer mode. Note that you have a bit newer version than mine :). AFAIR i had the same message in a multiplayer mode. I think that the problem is on the server side, or maybe it's sth wrong with punkbuster etc. which isn't supported by MorphOS version. I had a similar problem with TrueCombat, i couldn't connect to any server (there was one working two years ago), so i set up my own server with *important* +sv_pure "0" parameter, otherwise you will have similar "features" :).
  • »11.02.08 - 12:13
