OpenTTD with music
    Phantom
    Posts: 381 from 2004/9/7
    I like this game, and I download every new release comes out. Unfortunately, I cannot hear the in-game music. I copy the "GM" folder into my OpenTTD folder (not the data folder as it says into the read me file), but I still don't have music.
    Has anybody a solution to this problem, or the MorphOS port generally have not in-game music?
    [ Edited by Phantom on 2007/9/27 3:16 ]
  • »26.09.07 - 23:15
    tokai
    Posts: 1289 from 2003/2/25
    There is no music support on MorphOS. There is an experimental (not fully implemented) timidity driver which compiles on MorphOS, but it doesn't produce output yet.
  • »27.09.07 - 13:15
    Phantom
    Well, I suppose to see music support on further releases of OpenTTD. It's a great port. ;-)
  • »27.09.07 - 13:34
    Posts: 915 from 2004/1/24
    @tokai
    "yet"? I thought that project was dead?
  • »27.09.07 - 19:00
    Phantom
    During my play the mouse cursor doesn't move smoothly (like normal), and also the "Fast Forward" button seems not to work. But these problems I didn't have with previous versions of OpenTTD. I have installed something wrong?
  • »28.09.07 - 07:30
    tokai
    If something doesn't is as smooth as before it's most likely a powersdl.library problem. I'm using version 11.11 and everything seems to be normal.
    Please note that fast-forward is highly depending on the power of your system. There are a few things you can do to increase its speed: Disable "Full Animations" in the popup menu of the 3rd button (the tool thingy) and play fullscreen (which is 8bit if powersdl does it right, which means no 8bit => 24/32bit mapping is required like in window mode).
    regards,
    tokai
  • »28.09.07 - 08:47
    Phantom
    When I am offline, and play OpenTTD, after a while the system freezes, and I must reset Pegasos!
    But when I try to be online during my play, everything is normal (no freezes!!). Any ideas?
  • »03.10.07 - 09:07
    tokai
    I cannot reproduce this here.
    I let it run w/o miami at all... no problems.
    I let it run with Miami running but beeing offline... no problems.
    I let it run with Miami running and be online... no problems too.
    I let it run and switched online/ offline a few times while it was playing.. no problems either.
    If you're sure that it is an OpenTTD problem then please send me a usable debuglog (getramdebuglog) or a quick way to reproduce the problem (do you do anything special in the game when it crashes?).
    regards,
    tokai
  • »03.10.07 - 13:14
    Phantom
    Tokai, I will try it (to say the truth my big brother plays this game day-night), so I don't know exactly what he did and freezed the game.
  • »03.10.07 - 16:32
